Author Topic: Nyle door gasket kit  (Read 1125 times)
Offline acewoodturner
« on: February 01, 2014, 02:13:53 PM »
I am in the middle of designing my kiln. It will use a Sauno mechanism but will be roughly designed on the Nyle kiln. I really like the way they have designed the door and I was wondering how much the gasket would cost to buy. Is Nyle the best place to buy it from. I am based in Scotland so shipping VAT at 20% and import duty will add a fair lump on to the cost. Is there an alternative I could use such as thin rubber sheeting or something similar.
Thanks for your assistance
Mike
Offline Brad_S.
Re: Nyle door gasket kit
« Reply #1 on: February 01, 2014, 04:18:32 PM »
I used a hollow oval shaped rubber gasket used by garage door installers that usually goes along the bottom of a door. I used it as a seal all the way around and felt it worked fine.
Offline scsmith42
    • Whispering Pines Farm
« Reply #2 on: February 01, 2014, 04:52:17 PM »
A really heavy duty industrial gasket source is an old fire hose.  The inner portion is rubber, and the outer portion is jacketed with an abrasion resistant material.  Plus you can usually get them for free from a local fire department.
Tom's 3638D Baker band mill
Offline Sawdust Lover
« Reply #3 on: February 01, 2014, 07:01:36 PM »
I used my rubber floor mats in my shop. They are about 1/2" thick and I cut them in 4" strips 4' long and placed them all along the edge of the door. There is lots of different possibilitys on making a cheap door gasket that works.
Offline Den Socling
  • just wondering
« Reply #4 on: February 01, 2014, 10:45:27 PM »
As Scott said, old fire hose works. I have seen commercial conventional kilns use hose on big doors.
Offline Escavader
  • Sawmill/Planermill operator since1984
« Reply #5 on: February 15, 2014, 09:55:35 PM »
I've had best results on our large kiln doors using two gaskets side by each big difference in heat loss I use One of those heat checker guns to check for heat loss and there isn't any using two more pricy but we heat with kerosene and every little thing helps the bottom line
Alan Bickford
Hammond lumber company/Yates American A20 planer with dbl profilers Newman feed table multiple saw trimmer destacker automatic stacking machine Baker resaw MS log corner machine  4 large capacity Nyles dehumidification kilns JCB 8000 lb forklifts woodmizer lt 15 and mp100 and blower
Offline GeneWengert-WoodDoc
« Reply #6 on: February 16, 2014, 02:15:02 PM »
I also have seen old fire hose used, especially for the bottom sweep.
Offline Escavader
« Reply #7 on: February 16, 2014, 07:43:40 PM »
I'm looking for something for the bottom to lay in after the door is closed.Don  Lewis said some lay a folded piece of rubber roofing in .we are currently tearing down all four of our chambers  due to rot ,and replacing all new.when they are all done we are hiring a rubber roofing company to do the roof hopefully I get some then.we currently and always have used bark , but it's messy and when it drys out the 4 large fans blow it throughout the chamber
Alan Bickford
Nyle kiln gasket
Started by acewoodturner on Drying and Processing
Last post August 24, 2014, 10:11:31 PM
by GeneWengert-WoodDoc
E-2300 door gasket
Started by JJ on Firewood and Wood Heating
Last post December 30, 2013, 01:27:02 PM
by Logging logginglogging
Heatmor door gasket ?
Started by dave_dj1 on Firewood and Wood Heating
Last post December 08, 2019, 09:47:54 AM
by chevytaHOE5674
E-classic door gasket
Started by upsnake on Firewood and Wood Heating
Last post March 04, 2011, 09:18:04 AM
by upsnake
