Author Topic: can somone tell me how to change the oil line on my 266 xp ?  (Read 486 times)
Offline treechopper40
  • cut it skid it load it truck it
« on: February 01, 2014, 09:10:56 PM »
hi do I need to split the cases to change the oil line on my 266 husky or is there another way please help
1979 c5d treefarmer 1966 c5b treefarmer prentice g model loader 2 6100 dolmars a 6400 dolmar and a 7910 dolmar 2012 ford f 250 4x4 with a service body and 2 golden retreivers
Offline AKDoug
Re: can somone tell me how to change the oil line on my 266 xp ?
« Reply #1 on: February 02, 2014, 02:18:15 AM »
It connects to the oil pump and passes through the wall into the oil tank. It is replaceable without splitting the case.
Offline sablatnic
« Reply #2 on: February 02, 2014, 03:59:02 AM »
Just remove the clutch and the oil pump, and there you are, it's the round rubber thing.
And while the pump is out, take a look at the crank shaft seal, if it is worn, replace it, and replace the one in the other side too, as it most likely has run just as many hours.
Offline NCFarmboy
« Reply #3 on: February 02, 2014, 07:39:30 AM »
Very good advice.  I would replace seal and O-ring while I had oil pump off.  Cheap insurance.
Shep
Lots & Lots of Saws
What are the significant change years to the LT40 Line of Woodmizers?
Started by MikeySP on Sawmills and Milling
Last post January 27, 2019, 05:54:18 PM
by uler3161
this might interest somone
Started by sawhead on Sawmills and Milling
Last post January 14, 2004, 07:56:22 PM
by Jeff
Change band brands...change tracking?
Started by kelLOGg on Sawmills and Milling
Last post July 21, 2014, 05:56:28 PM
by ladylake
I dug thorugh the electric line, phone, and water line
Started by ozarkgem on General Board
Last post April 20, 2015, 08:41:07 PM
by ozarkgem
