YUK!
Started by CCC4, February 10, 2014, 07:48:01 PM
coxy
thats not to bad wait a few mounts around here it will be 5x that much mud :D :D 8) 8) 8) 8) 8) 8) nice skidder    that a 460 jack
CCC4
450C, yeh, the mud will get bad here also. We have been in a really bad drought
Southside
Just about lost my boot today a couple of times.  Not bad where I have been over it only once or twice, but the yard and main skid trail would make a mud runner some happy.
White Oak Meadows
thenorthman
When you lose a tire and you can't find the skidder op, then you gots mudddd! :D
well that didn't work
coxy
Quote from: CCC4 on February 10, 2014, 08:43:31 PM
is that your job
CCC4
What, skidder OP? Not unless I just have to! LOL! No, I'm the cutter...well this tract is hydro Ax job and I'm only cutting some rough areas. This job I just chase the Hydro Ax.
ScottAR
Our mud is frozen again...  Supposed to start warming Wednesday.
Scott
[Magicman]
coxy
Quote from: ScottAR on February 10, 2014, 11:13:24 PM
send some warming my way  I think I would rather deal with mud at this point  ??? sick of the cold and snow >:( >:(
timberking
That don't look bad considering all the rain.  At least you are working.  Looked at the map for Dolph and surprised you found a flat spot to deck.
Stinny
Back in the late 70s I was up north here in Maine, above Presque Isle. It had been a terrible fall for the potato farmers with rain storms, one right after another. I remember looking out across a field and seeing a potato harvester buried in the muddy field, with 2 skidders all hooked together... also buried. What a mess.
Suzuki 4x4 on Tatou tracks tugging logs in winter
CCC4
Yep! 50's Thursday!  8)
CCC4
Quote from: timberking on February 11, 2014, 02:57:53 PM
We have had a really bad drought up till this snow, it could be much worse as far as the....mudd. This unit is mostly flat ground. Been cutting the ridge lines and bottoms today. I prefer the slopes myself, it's more how I'm used to falling timber...but flat ground can have it's benefits!  :D
