Author Topic: sketchup  (Read 808 times)
Offline steve marek
sketchup
« on: February 17, 2014, 07:38:36 PM »
I was wondering if anybody could help me out where I could down load sketchup for timber framing is there a  site where you can buy the program. Will it figure out what size timber you need to build a building? Is there a big learning curve is it user friendly.
        thanks steve
WM LT40HD Logrite ach 718 woodmaster timber framing tools 3000 ford tractor 359 395 husky chainsaw woodmizer e50 single blade edger woodmizer 260 moulder 2538 mahindra tractor kd 250 kiln
Offline VictorH
Re: sketchup
« Reply #1 on: February 17, 2014, 07:52:50 PM »
Hi Steve
The standard sketch-up is free.  I have heard that the rubies used for the joints are now included in the library but am not sure of this.  It does not calculate the size of timbers you need.  there are a a lot of variable that determine the size you need- some of them are > snow load, roof material weight or load, type of structure, barn or house or business, and wood type.  It is not that hard to use or to learn to use. There are a lot of tutorial videos on youtube.
Victor
Offline witterbound
Re: sketchup
« Reply #2 on: February 17, 2014, 08:19:17 PM »
If you're a computer person, then you can learn to use sketch up to design a frame.  It does take time.  I work in an office and use my puter for excel and word processing.  I learned to use sketch up and the rubies in a few weeks, spending many hours each day.  It does not design or size anything.  It draws what you tell it to. It is a wonderful way for those of us who don't have the time to learn autocad to draw with a computer.
Offline bigshow
Re: sketchup
« Reply #3 on: February 18, 2014, 08:31:07 AM »
witterbound,
would it be fair to assume you were messing around with sketchup while you should've been tending to your spreadsheets and docs at work? :)
I never try anything, I just do it.
Offline bmike
    • Mike Beganyi Design and Consulting, LLC
Re: sketchup
« Reply #4 on: February 18, 2014, 08:41:58 AM »
You can download a free version.  The TF Rubies are an add on extension and can be found in the Extension Warehouse. They have more to do with a specific way of detailing timber frame joinery than with designing frames and buildings and are not needed to get started (and I would suggest you learn how to use the program before even attempting to use them).
I do not use them in my daily work, but they do help you speed up work for certain types of production detailing.
www.mikebeganyi.com
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: sketchup
« Reply #5 on: February 18, 2014, 10:36:05 AM »
Understanding what size timber to draw may take some education.
Software can only out put what you want if you know what to input. Garbage in, garbage out.
If you read this thread:
http://www.forestryforum.com/board/index.php/topic,50714.0.html
you will see how we went step by step looking at the loads a timber will carry and how to figure out what size to use.
You could try and follow along on this and see how it goes for you.
Jim Rogers
Offline witterbound
Re: sketchup
« Reply #6 on: February 18, 2014, 08:21:47 PM »
witterbound,
Might be right, but I'm not 'mittin' anything....  :)
Offline steve marek
Re: sketchup
« Reply #7 on: February 22, 2014, 12:39:00 PM »
Thankyou for feed back check on y-tube looks like it should not be to bad lots to learn I downloaded it from the internet I'll sure I will have ? thanks again for in put
Sketchup Make v Sketchup Pro
Started by MbfVA on Timber Framing/Log construction
Last post September 04, 2017, 09:02:23 PM
by MbfVA
Sketchup!
Started by Tullivor on Timber Framing/Log construction
Last post November 29, 2012, 08:32:00 PM
by wkheathjr
Sketchup tip
Started by zelpatsmot on Timber Framing/Log construction
Last post March 09, 2012, 10:20:43 AM
by beenthere
SketchUp
Started by DouginUtah on Timber Framing/Log construction
Last post January 20, 2012, 01:10:32 PM
by ballen
