gearamatic whinch cable?
Started by treefarmer rick, March 11, 2014, 11:14:18 AM
treefarmer rick
hello folks I have gearmatic 19  winch anchored to a c5, it is in need of a new cable. It currently has a 9/16 fishing line on it which is no match for the setup. My question is should I go with 100ft of 3/4 or a 5/8 swedge. Also any american supplyers you deal with for your purchases of these products. Thanks for any and all input. Rick.
coxy
I have 3 gearmatic winches one a cat one case one pettibone  with 6- 7 and8 sliders and run 9/16 on all of them with out any trouble           ???
treefarmer rick
maybe it is just old, but it does not take much of a snag to snap the end. If I hook two /three  30inch full trees it is history. Cant see pulling one at a time.
treefarmer rick
I was wrong just measured the dia  it was 1/2'' at most
BargeMonkey
 Comstock Logging supply.  I buy all my cable and log supplies from dick, his website doesnt show everything, best to call. Dont know where your from, he services NY-MA-VT. Personally I run the good swaged 3/4 down to 5/8. Little bit heavier but lasts a bit longer.
coxy
on my cat I pull 8trees 18- 23in with all the wood and never had a prob  I don't winch in 2nd gear or stand the skidder on one wheel or do wheelies with them so my be that's why I have good luck with it   and its a hole lot easer to pull 9/16 up the hills I work on :) ;D ;D
treefarmer rick
jwilly3879
A lot of making a cable last is how you are hooking up the trees. We usually try to leave the last slide open to pick up a piece along the road, pull the first tree up to the next and hook to the slide ahead of the first tree and so on. Seems to work for us and we usually run 9/16 crane cable.
UN Hooker
That 9/16 crane cable is some tough. In the early "80"s, at an auction I bought a 4' dia. reel of it.  Still got about 3/4 of it left. I've never broken it, but after a long while it will fray and my wife doesn't like getting her hands stuck  >:(  so I pull it off and put on a new one.
             UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
HiTech
I run 9/16" cable and love it. Easy to pull and use 5/16" 100 grade chokers also easy to carry. The 9/16" cable is over 40,000 lb. breaking strength so it will take some abuse. 3/4" swaged 65' long will work good if you are a cowboy and just slam bam everything. You can hang your skidder on that stuff. Over 70,000 lb. breaking strength. It all depends on how you treat stuff.
treefarmer rick
I am pulling up a steep banking, cant really see what is going on down below. I am only pulling on an idle or just a little throttle, so there is no hot rod tree pulls going down. It just seems that if I happen get into a spot the needs a little grunt to get the butts up and out , the end of the cable snaps like butter. Like I said not wide open pulling. J ust seems to be to underated of a cable for what it is hooked to. I measured the cable and It looks like 3/8 -7/16. thank you for your info
Stephen Alford
   Hey Rick , just to throw something in the pot  ;D , I use 1/2'' skidder cable. It works on tractor and skidder both.  I know most lads on here use heavier cable.  Our wood is smaller but I run 12 sliders about 3/4 cd per twitch.  I look at cable as a   "consumable"   but at 125 each a great price for what they can do. Sounds like the one you have is past its due date.  ;)  With a bit of chain oil on the fairlead ,reversing after 5 months then end up replacing at about 8 months.  If your working side hill fatigue will be less with the 1/2".  Oh and if that is a detroit in your c5d best not to idle any more than you have to. Stay safe.   :)
logon
treefarmer rick
coxy
Quote from: Stephen Alford on March 12, 2014, 10:24:10 AM
what do you mean by reversing   take it off turn it around ??? :)
Stephen Alford
Exactly.   My "ol doll" is a 79 so thats 35 years working in the woods.  I have found that when your yankin cable your body is under load so injuries and fatigue make a difference. The 1/2" is so easy to work with especially if your a tad older than most of the young bucks on here.  When the cable goes get another.  ;D  Its like an ol timer told me once " boy if you would only learn to file that saw you would not have to lug so many cc's"   :D
logon
