My red oak is blue?
Started by sparky23, March 20, 2014, 07:58:29 PM
sparky23
For sale...100+ acres of nicely wooded land..lol :(  lots of nice limestone to build on!  :D
Al_Smith
I don't think limestone causes blue stains .Lawdy if that be the case we'ed call the local red oaks blue oaks .
SLawyer Dave
Disclaimer, I love a good puzzle, and I put myself through law school as a State Certified Wood Destroying Pest Inspector, so this kind of "mystery" is pretty fascinating to me, (God I lead a boring life),   :D
So I am very familiar with the various forms of "wood rot", (fungal infections), and through organic and inorganic chemistry, I think I have a pretty good idea of the types of minerals, pathogens, and enzymes that could cause such a unique color.  Then there is the mechanism of how this "stain" was delivered to the internal stress cracks of the standing, living tree.
There is a "blue fungus" that mostly infects softwood trees, (Pine is a prime example).  "Blue Pine" is very prevalent and is caused by a fungus that pretty much grows in any pine that is dead or dieing.  However, I have never seen or heard of this common condition creating that vibrant of a blue green color.  This is also called "sapwood staining", and generally spreads throughout the sapwood, not just the internal cracks as your trees indicate.  The only thing I have seen in "nature" to cause that type of bright blue-green color before is chlorophyll.  That is why I don't think it is a fungus, because the "fungus family" doesn't use chlorophyll for photosynthesis.  Similarly bacterial and mold infections would not seem a likely source of such colors.
There are a few minerals and oxidations of certain metals that could form that color, but I can't see how the mechanism for distribution would occur through such internal cracks.  While my logic can certainly be flawed, the only explanation for the distribution of the stains to me points to the stain coming from the top down, along those internal cracks due to gravity and water infiltration.  Other than chlorophyll, the most common sources of that range of colors in nature would probably be oxidation of Cobalt and Copper.  However, since these minerals would not be "sucked up" through these internal cracks, (like mineral staining coming up the cellular walls), again, the only answer that makes sense would be that the source of the stain would have to come from the top down.  So again, how did such minerals get into the top of the tree, to then oxidize and wash down into those internal cracks?  Given the difficulty of coming up with such an answer, I still believe it is chlorophyll based, which would most likely come from an algae source.
Of coarse, I have no way to confirm this, but it is the best explanation I can come up with.
Ron Wenrich
The other way of movement is through osmosis.  But, the only real active area of a tree is in the cambial layer which transports water from the ground and sugars from the chlorophyll.  Blue stain affects the sapwood.  Blue crack is in the heartwood.
Tulip poplar gets a blue or purple streaks in the wood, and I've seen it mainly associated with an injury.  Its supposed to be due to potassium in the soil.  I've seen where its hit or miss in a stand.  If it were a soil condition, I would think that all the trees would be affected, and not just a select few.  The same could be said for the blue crack stain.
If you go with logic, I've seen it associated with rot.  I guess the question would be did the rot cause the blue, or did the blue cause the rot.  Jeff indicates that its in stands on poor sites in his area.  In my area, that's not true.
isawlogs
  Very interesting thread, hope it continues till the issue is resolved.  :P
   Marcel
SLawyer Dave
Quote from: Ron Wenrich on March 25, 2014, 06:18:54 AM
I can't imagine the "blue crack staining" like we are seeing in the pics, not associated with water intrusion.  Where you have water inside a tree, you will always have some amount of fungal presence.  Depending on how much moisture, and for how long it stays moist, is going to in large part decide how intrusive/severe such fungal infestations will be.  So I would anticipate these two different "issues" to be found in association with each other.  This should especially hold true if we are dealing with both an algae and fungal infestation, which both require excessive moisture conditions to be present.
Ron Wenrich
Algae needs light.  No light in the interior of a tree.
The only blue stain I have seen in the interior of pine (white pine), usually just the sapwood,  had a mode of transport. That was by ambrosia beetles. The stained wood clearly has ambrosia bore holes. Then of course there is the airborne kind of fungi that inoculate wet pine lumber. Often times we look, but don't observe and therefore don't really see the cause. What are we not observing and not seeing in that oak? ;)
In maple you get what is called ribbon streak (edit: actually the correct name is pith fleck). In this case it is a fly larva, and the wood does not stain. The tree heals it since it is still a live tree with living cells and the scar tissue (if you will) is a brown color. This happens over many generations during the life of the tree.
Those ribbon streaks are common in red maple down here.
isawlogs
Swamp., Blue stain in white pine can be had with heat with out the beetles. One can saw pine stack it and in the sun with out the stickers and I can garanty blue stain will happen.
   Marcel
Ron Wenrich
Blue stain is so prevalent, its in the air.  That's why you can saw green lumber, and it will give you the blue stain.  Blue stain only works in sapwood, and not heartwood.
This blue/green color is associated with heartwood, so that would exclude blue stain.  Also, the color isn't right.  In red oak, blue stain will effect the sapwood and the color is more blackish than blue.
We get worm streaks in our soft maple.  I was always told it was ambrosia beetle.  It looks to me like they get into the cambial layer and do their dirty work.  The tree then heals it over and causes a grey streak.  You'll get the same thing in tulip poplar from the Columbia beetle, and it will give a black streak.
isawlogs
  I have had some bleu green stain in oak that had been sitting in the sun and heated some.
   Marcel
Quote from: isawlogs on March 26, 2014, 08:46:18 AM
You forgot to read the part of the post about it in the air, like Ron said to. ;D
Also, how long did the pine lay stacked before it was sawed? Those little b%^% can have time to inoculate your pine while it sits for 6 weeks in a pile outside. Grandfather cut white pine one winter for mother for cupboards, when it was finally sawed the lumber turned all stained and no good for cupboards. Also an infected saw blade can spread fungus around.
The grey streak stuff in maple is ambrosia, I have some here to. It is not the ribbon streak caused by the fly. Ribbon streak is not stain, it is scar. My mistake though in the term, it is actually called pith fleck caused by phytolobia pruinosa.
isawlogs
 That must of got lost in translation....  :P ;D :D
   Marcel
I have stacked fresh sawn pine before, but they were cut down in the fall, sawn in May the next year. Looked nice and white when stacked, but that fungus grew all over it, had stickers, had them ambrosia to as I discovered. Wasn't the air, was the bugs that began it and then the saw spread it around good.   ;D
SLawyer Dave
Quote from: Ron Wenrich on March 26, 2014, 04:56:18 AM
Absolutely, which is why I referenced having an elevated water source where the algae would need to be active.  I have found numerous "voids", (water catches), often times in lost limb bases, or in the crotch of large limbs, that contain water and are exposed to light and have active algae growing in these "pools".  My thought was that as the algae dies, it settles to the bottom due to gravity.  If the water containing these dead cells (which carries the chlorophyll), wash down into these internal cracks, then so does the chlorophyll.
Ron Wenrich
If the water would settle out due to gravity, wouldn't the pools drain and there would be less algae?  I also don't think that water activity in a tree works in that way.  Water goes up in a tree, not down.  There is no water movement in dead xylem tubes, but the do contain water from when they died.  Otherwise we wouldn't need dry kilns.
You would also have to figure a way to offset the theory in white oak, where the dead xylem are occluded during tyloses which makes white oak a waterproof type of wood of sorts.  That's why they use it for making whiskey barrels.
I don't recall ever seeing the blue green in white oak.
Ron Wenrich
I'm pretty sure I've seen it in white oak.  It might not be as prevalent as what's pictured, and its always associated with rot.  Growing conditions and genetics are different in my area than in yours, so that could be part of the issue.
sparky23
I gotta say I wasn't expecting this kind of response! I'm kind of confused tho..is there any sort of consensuses as to whether it's mold, algae, mineral stain, or limestone? I can probably get some other pics if that would help..
SLawyer Dave
Quote from: Ron Wenrich on March 27, 2014, 05:42:51 AM
Its been talked about in a number of threads how many oak trees tend to "hold water" in their trunks due to voids and internal cracks.  I've seen this hundreds of times myself.  It is very common for me to cut into a living standing oak tree, and to have anywhere from a few quarts of water, to a number of gallons come running out of the tree once the chain cuts into such voids.  The point is that this water does not come from the ground up, but rather from the top down as the water is finding its way into these voids due to cracks, water catches and injuries in the tree that are allowing the water to infiltrate.  Once these voids are full of water, then a pool or standing water generally forms in the open void/water catch where the water gains entrance.  Certainly, there is going to be evaporation and a certain amount of water that is going to be absorbed into the tree, which would make the water level in these voids fluctuate, but unless these voids/cracks continue down into the roots, and ultimately to soil, then the water really doesn't have a chance to come out the bottom.  Rather, the water continues to generally be trapped in these voids.
Given that the algae and its "bloom" is going to only exist in the area of the water receiving sunlight, the dead cells are going to naturally sink, (in this basically still water that has no outlet).  That is the mechanism of how the chlorophyll *could* be introduced to the interior of these voids and cracks.  While I have already agreed that one or more wood destroying fungus would likely be present due to this water intrusion, please note that where the water is completely filling up the void, fungus can not grow due to it needing free oxygen.   I just had a tree I fell a couple of weeks ago like that.  Gallons poured out of the tree when I cut into the void, which turned out to be a long central "crack" that ran for about 30' up the center of the tree.  Yet, while the wood was stained a very brilliant "black", there was almost no fungus or related softening of the interior wood.  The water was constrained inside that void, and due to it completely filling the void, fungus could not grow.
While yes, through osmosis and even wicking, I would agree with you.  We are not talking about a "biological" movement of water up the tree, however, we are talking about water intrusion through the bark/cambrian layer of the tree through either a wound, crack or other abnormality.  Once that water enters the interior of the tree, then gravity is going to reign supreme, and try to pull it down.  If that entry point, then is connected to any internal cracks or voids, then the water is going to "run downhill" into such cracks and voids.  Again, unless such cracks or voids have some sort of "outlet", then the water is going to become trapped in such voids.
I agree with you in principle, however, again we are not talking about a biological conduit to water or moisture as would be moving through a cellular wall, but rather simply a mechanical flow of water through physical voids and cracks within a tree.  It doesn't matter how well something is "water resistant" to penetration, when there is a physical break or void that allows water to flow through or past such barrier(s).  Think of a concrete dam.  The concrete is itself a continuous water resistant barrier through every dimension of its shape and size, but if there is a hole or crack through this material, the water will flow right through it.
For me, the issue of the water accessing the interior voids and cracks within a tree through such injuries and water catches is a very common experience.  I see it at least monthly in the oak trees I fall and cut up.  Sometimes these voids also contain a lot of fungus damage, sometimes they do not.  Most of the time, I see a dark staining associated with such water filled voids, that sometimes is a bright black to a dull almost purple.  What amazed me about these photos was the brightness and vivid color of the staining within these internal cracks.  I've never come across anything close to that color in a plant, (except chlorophyll staining), but even that was in a lab.
Again, I acknowledge that I have no way to prove this theory.  The only way to be sure would be to submit a sample of the stained wood to a lab so that a culture could be taken for both microscopic examination and chemical analysis.  However, at the same time, I can't come up with a "better" explanation that seems to fit all of the other information that we have.  So through nothing more than Occam's Razor, it would seem the best explanation I can come up with.  I'm hoping someone else may have some additional ideas or knowledge to share.
sparky23
I wouldn't even know how to find a lab to bring this too...any ideas as to how to start my search?
Got any regional Forestry Canada centres near by, like at the Saulte? I doubt any provincial DNR's will even touch it. The ones around here are just interested in growing wood and spraying bugs.
sparky23
Just got off the phone with them in the Sault and I'm sending same pics as well as mailing a sample piece. I'll let y'all know what the lab says!
Jim_Rogers
I haven't read sawyerdave post #45 but to me that stain is usually near wood that is rotting.
I consider a stain like that due to rot. The wood is usually very punky and soft around that color wood.
But, I could be 100% wrong.
Jim Rogers
