Author Topic: .042 or .045 thick blades for 18hp LT15  (Read 1134 times)
Offline sawdusty1
« on: March 21, 2014, 12:19:17 AM »
What is the best thickness to run on the LT15 with 18hp?  I am cutting mostly hardwood with some pine.
Woodmizer LT15
Husqvarna 550xp
Husqvarna 372xp
Husqvarna 350
Husqvarna 55 Rancher
Husqvarna 181se
Kubota L4701
Offline Small Slick
  • No situation is so bad that I can't make it worse.
Re: .042 or .045 thick blades for 18hp LT15
« Reply #1 on: March 21, 2014, 12:43:27 AM »
I wish I had your answer. I got my lt15 in early December in Wisconsin 2013. I purchased the 9 degree blades for hardwoods/frozen timbers. All I have ever cut has been frozen. I'm not sure how thick the blades are.
Does .003" make that big of a difference?
John
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #2 on: March 21, 2014, 06:21:01 AM »
Good morning Sawdusty1,
Either will work fine,  its more important to get the right hook
angle (tooth degree),  lots of WM sawyers here speak highly of the 7 deg bands for hardwood.
Check the WM site for their band selection chart.
http://www.woodmizerblades.com/bladeTypes/doubleHard/doubleHard.aspx
DGDrls
Online pineywoods
« Reply #3 on: March 21, 2014, 10:07:58 AM »
My ole manual lt40 came with a 18 hp briggs. I used both .042 and .045. Can't tell any difference as far as sawing goes, but I found the .045 hold the set better over more sharpenings. I upgraded to 25 hp and now use .045 exclusively.
Offline sawdusty1
« Reply #4 on: March 22, 2014, 09:27:11 AM »
Thanks for the info.  Somewhere I had read that the lower hp engines would have a hard time pulling the thicker blades.  Good to know since I have already bought 35 .045 blades.
Woodmizer LT15
Husqvarna 550xp
Husqvarna 372xp
Husqvarna 350
Husqvarna 181se
Kubota L4701
Offline 5quarter
    • Blue Harbor Refinishing
« Reply #5 on: March 23, 2014, 01:53:09 AM »
x2 what piney said about holding the set. I can also saw the real wide cuts faster and straighter than with the .042" blades. .003" makes a difference.  I have been begging Cooks to buy a coil of .045" band stock but they won't do it. they discontinued them about a year ago.  ???
Has anyone tried .042 thick blades on a HFE-21?
Started by 21incher on Sawmills and Milling
Last post September 02, 2014, 11:44:53 AM
by coastlogger
how thick is your firebox. Mine from Central Boiler is not as thick as you think
Started by Mocha2324 on Firewood and Wood Heating
Last post March 15, 2016, 11:38:06 AM
by Bert
Need Help with 18hp B&S
Started by sawmiller7753 on Sawmills and Milling
Last post December 02, 2012, 11:58:27 AM
by Al_Smith
LT-30 Magnetron on a B&S 18hp
Started by buffhale on Sawmills and Milling
Last post March 30, 2015, 06:33:17 PM
by macpower
