Wood Mizer lt30g value
Started by e010198, April 11, 2014, 09:58:19 PM
e010198
It's a 1987 with 14hp kohler 96 actual hours.The mill has not been run in at least 20 yrs; it's parked under shed roof. All unpainted parts are rusted, but frame seems to be okay.
I figure to replace motor and all berings. Owner wants $6000.00 for it.
What would be a ballpark cost to rebuild the mill.
Welcome to the Forestry Forum, e010198.
POSTON WIDEHEAD
drobertson
seems a little high if a complete rebuild is in order, but then again, many used ones have been abused, if the rails are straight, and you are in for such a task, I would go for it.  I would consider the resale value of one like this in a refurbished condition, and go from there.  There are many factors even after the bearings are all replaced, and possible engine replacement.
mikeb1079
6k is waaay high imo.  i would be offering more like 1-2k tops since it sounds like you're looking at an almost total rebuild.
homebuilt 16hp mill
backwoods sawyer
Welcome e010198
Not a whole lot to be conserned about if it only has 96 hrs and lived under covered. Not like it has been thru a fire or a flood or in a wreck.
Surface rust cleans up with ease, few bearings, not a lot of belts and hose to change, check for rats nest in the electrical boxes. Is the motor shot or does it just need a good cleaning to get it to fire up?
I would contact Wood Mizer and get their Orange book value and go from there.  :P
Backwoods Custom Milling Inc.
dgdrls
Welcome e010198
By description I agree with Mikeb1079, seems high.
20 years of outside and not running didn't do it any favors.
For the added price of a motor, bearings and your time
which you will probably need to invest, you can purchase
a comparable new mill also from a FF sponsor (screen left).
Best
DGDrls
Chuck White
I think I would try to get the engine going and kick it in gear and see how it performs!  If everything moves properly, it should be worth the $6k.
The rust (assuming the main rails & mast rails) can be removed with steel wool, ATF, & elbow grease!  I wouldn't think it would need a complete rebuild!
I feel that if he's asking 6, he'd probably take 5!  Just sayin'!
For just a little bit more, you can get a brand new LT15 with the 18 HP Kohler.
mikeb1079
QuoteFor just a little bit more, you can get a brand new LT15 with the 18 HP Kohler.
nuff said.
homebuilt 16hp mill
Give WM a call with the S/N.  They can give you the complete history on the sawmill and also an "Orange Book" value.
Here is the LT15 that WDH was referring to;  LINK
