Author Topic: pico chain  (Read 8375 times)
Offline grampt1
pico chain
« on: February 19, 2002, 07:35:36 AM »
Has anyone had any experience with the pico ripping chain in a portable saw mill, does it have a smaller kerf than granberg or oregon ripping chain? The only place I have seen this chain is in the logosol advertisment, is this the only place it is aviable?
Ron
Offline psychotic1
  • Earth First   We'll log the other planets later
Re: pico chain
« Reply #1 on: February 19, 2002, 11:04:57 AM »
Hello Ron, and welcome
I haven't had any real experience with the pico chain, but I have studied the logosol mill brochures and video intensely.  Basicly the pico ripping chain is the same sort of stuff as the low profile chains you find from other manufaturers.  It takes about a .25 inch kerf compared to the 3/8 of "normal" chain.  You should be able to get the pico chain at your local stihl dealer.  I've heard on the net though that some of them don't know what your talking about.  Oregon makes a low-profile chain.
Bruce
Ps. Anything I forget Kevin?
Patience, hell.  I'm gonna kill something
Re: pico chain
« Reply #2 on: February 19, 2002, 02:42:46 PM »
Kevin ! !..............Ke-e-v-i-i--i-n--N
Where'd you go Kevin?............Anybody seen Kevin?
Offline DanG
Re: pico chain
« Reply #3 on: February 19, 2002, 07:27:26 PM »
Last I heared, he wuz up in Canuckadadia, somewhere. Probbly out chainsawing a whack of lumber by the light of the moon.
Offline Kevin
Re: pico chain
« Reply #4 on: February 20, 2002, 06:38:40 PM »
To the best of my knowledge Stihl picco chain was designed for small lightweight saws.
I wouldn`t consider it for milling chain.
The new craze with milling chains is to go small and use a narrow kerf.
Been there, done that, don`t care for it and won`t recommend it.
Offline psychotic1
Re: pico chain
« Reply #5 on: February 20, 2002, 11:28:16 PM »
The saw that comes with the logosol mill is a stihl 066 set up with a 16" bar and two picco chains.  They claim they worked with stihl (another swede company) to set this up.  What don't you like.  Not strong enough?  Does this also include the low profile chains?  enquirring minds want to know...
Bruce
Offline Kevin
Re: pico chain
« Reply #6 on: February 21, 2002, 10:00:46 AM »
Bruce, low pro chains are lighter which make them weaker and prone to stretch for use in  milling.
I think once you find something that works well for you, you`ll stick with it.
I know some people like the low pro chains and if they`re happy with it they`ll probably continue to use it.
Low pro chains were designed for Arborists and I think they are well suited for that purpose.
Offline psychotic1
Re: pico chain
« Reply #7 on: February 21, 2002, 12:48:38 PM »
I have seen that same comment on a couple of other websites, but thought if the manufacturer said it was ok...
Maybe I'll use it on the 16" bar for little stuff, but not on anything bigger.
Thanks Kevin
Bruce
CharlieJ
  • Guest
Re: pico chain
« Reply #8 on: February 26, 2002, 05:41:00 AM »
I haven't used Picco chain but I have used low profile from baileys and Oregon. I also use 3/8 Oregon 72R. 91vs low
profile from Oregon makes the best ripping chain. it does
stretch but just keep adjusting untill it quits. I have never broke one
even when I sawed thu 3 20p nails.
Charlie
Offline Kevin
Re: pico chain
« Reply #9 on: February 26, 2002, 02:34:07 PM »
Charlie,
I`m putting together a team of doctors who will help wean my fellow millers off that garden chain you`re now using and get you started in a rehab program in order to get you using RA on your milling saws.
Recent testing is showing some real positive results!
CharlieJ
  • Guest
Re: pico chain
« Reply #10 on: March 01, 2002, 09:42:39 AM »
Well Doc,
Yes I do use that narrow stuff
No I am not sick
I do use RA sometimes but its SLOW
Yeah Doc I did drive A GTO in my youth
I know but its so much faster and saves wood, NARR kerf you know............
:D
VVVVVVVVVVVVRoooooooom
Offline Kevin
Re: pico chain
« Reply #11 on: March 03, 2002, 11:11:51 AM »
Charlie, that garden chain is ok for holding up your pants but it`ll shake your teeth loose over time and then you won`t be able to chew the rag anymore!
I want you to try the patch, it`s one link of RA and all you do is tape it to your arm and within a month or so you won`t even want to look at that bathtub stopper chain you`re using now.
CharlieJ
  • Guest
Re: pico chain
« Reply #12 on: March 04, 2002, 09:07:13 AM »
Sorry Kev,
91vs runs as smooth as RA   8) 8) 8)
Offline grampt1
Re: pico chain
« Reply #13 on: March 06, 2002, 09:49:11 AM »
TEXT
Charlie
 How do you think the 91VS would work with my Stihl 046 with 105 drive links?
CharlieJ
  • Guest
Re: pico chain
« Reply #14 on: March 06, 2002, 10:27:29 AM »
Grampt
I use a 24" bar with 84 drive links so I don't know for sure but
if I needed a longer bar i would try it. It may need to be adjusted
a lot at first but I can't see why it wouldn't work.
Offline grampt1
Re: pico chain
« Reply #15 on: March 07, 2002, 04:08:25 AM »
Thanks Charlie for the information!
 I can't make up my mind as to try the low profile chain or not, I guess I am just chicken,with a 32" bar that's a lot of chain flying around if it did break, but it sure would be nice to speed up the milling process.
Ron
CharlieJ
  • Guest
Re: pico chain
« Reply #16 on: March 07, 2002, 04:45:23 AM »
Grampt,
Get one and use it the first time after you have slabbed a big log
and have a nice clean cant to bury all that chain in. 91 will run on a regular 3/8 bar. Or get a shorter bar setup to use in smaller logs.That alone will speed you up.
Offline grampt1
Re: pico chain
« Reply #17 on: March 07, 2002, 06:28:41 AM »
CharlieJ
 Do you file the 91 the same as 72R?
Ron
CharlieJ
  • Guest
Re: pico chain
« Reply #18 on: March 07, 2002, 09:16:22 AM »
Ron,
Yes 10 degrees across the top plate. Because the cutters are
short I only take a little off each time untill the entire cutter is 10 degrees this takes 4 or 5 filings. this doesn't seem to affect the cutting speed or smoothness much. File the rakers to .30 or .35
Charlie
Offline grampt1
Re: pico chain
« Reply #19 on: March 08, 2002, 03:59:31 AM »
CharlieJ
 Thanks a lot for all your help.
Ron
Pico rim part number for 056?
Started by Enderslbz on Chainsaws
Last post October 25, 2014, 10:49:41 AM
by HolmenTree
Mill Chain, Heavy Duty Conveyor Chain' etc
Started by splitter on Wanted
Last post July 12, 2008, 11:34:36 AM
by TexasTimbers
Oregon Chain Grinder vs. Stihl chain angles
Started by Chelsea Tree on Chainsaws
Last post July 08, 2013, 07:58:36 AM
by bandmiller2
question
Recomendation for chain saw & chain for wood slabs
Started by Mike in Texas on Chainsaws
Last post October 29, 2017, 01:33:30 AM
by Ianab
