Author Topic: Most Unusual Object Found In a Saw Log  (Read 11040 times)
Offline prittgers
  • Wood-Mizer LT50, JD406, Inventor of the Bevelsider
    • AKSawmill.com
« on: June 21, 2014, 02:12:03 PM »
What is the most unusual item you encountered in a saw log?  For me, it was a glass telephone line insulator.  Even a Woodmizer would not cut that one!
Parker Rittgers
Professional Sawyer, Retired, well, not really !
WoodMizer Alaska | 907.360.2497 cell 336.5143 office BevelSider.com ? Everything BevelSider
907.336.5143
prittgers@aksamill.com
Offline hacknchop
Re: Most Unusual Object Found In a Saw Log
« Reply #1 on: June 21, 2014, 02:27:30 PM »
Hit a 4"stone in the crotch of an oak log bent the mandrel on a mobile dimension mill! !
Often wrong never indoubt
Offline Tony
« Reply #2 on: June 21, 2014, 09:37:54 PM »
      Milled 4,000bf of ERC a few years back, hit 1 marble :o :o :o :o :o
                                                 Tony    8)
TK1600, John Deere 4600 W\frontendloader, Woodmaster718 planer\moulder, Stihl MS461 Stihl 036 & 021 & Echo CS-370
"You cannot invade the mainland United States.  There would be a rifle behind each blade of grass."  Adm. Isoroku Yamamotto ( Japanese
Offline mesquite buckeye
  • Trees are good- even ones with stickers
« Reply #3 on: June 21, 2014, 11:20:17 PM »
Bunch of bullets, nails and a complete pan trap with 4 foot of chain. :-\
Offline GAB
« Reply #4 on: June 22, 2014, 01:41:58 PM »
My dad hit a ceramic electrical insulator in a log once.  Dulled every tooth of the chain.
In logs, with the sawmill, I have hit ant nests, nails, bullets, barb wire, and I did saw a 1/2" lagbolt in the third or fourth pass sawing 1" boards.
I have also hit the first log stop three times.
Ah-yup, I have scrapped a few blades.
Gerald
Offline Den Socling
  • just wondering
« Reply #5 on: June 22, 2014, 08:17:26 PM »
I used to be a consultant for a company that cut logs from the vicinity of strip mines. There were all kinds of glass insulators and tramp metal in them. They had this big old circle saw with a magnetic starter. When they hit something, carbide would fly. Everybody would duck and wait, wait for the blade to stop spinning. There were holes in the roof above the blade. Anyway, I put a electronic starter with a brake on it in short order. That crap can be dangerous.
Offline dutchman
  • Sawyer SW PA TimberHarvester 30HT
« Reply #6 on: June 22, 2014, 09:38:32 PM »
Nice piece of red oak from Clarion County.About 26" dia.
Tried to open 3 faces, first face hit metal about 1 ft in,
second face thinner slab, in about 18" hit metal,
third face about 1 ft in same problem.
Chainsawed 2 ft off the end found iron stain, Railroad spikes.
Someone must of had a tree stand in that tree and used sipke
for climbing up.
Offline mrector
  • eager to learn
« Reply #7 on: June 23, 2014, 11:43:19 AM »
I did not hit this with the saw but found it while pressure washing a log. It was buried in a Doty place in the crotch of a 30" maple.. it was a hot wheels car.. late 60's model vette.
Mikey
Woodmizer LT35HD25 brand new!
Stihl 044 and my favorite: ms260 pro
Homemade logging arch
Homemade hitch log picker-upper
DanG Deadheader log loading trailer.
Offline dboyt
  • Log On!
« Reply #8 on: June 25, 2014, 09:58:44 AM »
I was milling at a customer's site and struck a big piece of metal.  I rolled the log off the mill, changed the blade, and loaded the next log.  Out of curiosity, the customer cut the metal out with his chain saw, and produced an ax head, exclaiming, "I've always wondered where I left that!"
I've also milled into cement.  Seems years ago a lot of people thought it was a good idea to fill hollow trees with cement.  That will destroy a blade in no time.
Online Banjo picker
« Reply #9 on: June 25, 2014, 01:01:59 PM »
Bumper Jack.   Used to tighten a line for drying clothes. Some how. I cut it off.  Should have taken a pic.
Offline LittleJohn
  • I am not a professional, I just pretend I am...
« Reply #10 on: June 25, 2014, 01:49:48 PM »
...I have also hit the first log stop three times...
How hasn't, hit one of those!!
Mostly bullets, a few barb wires, a shot gun slug.
I once missed an actual metal fence post; someone must have leaned the post against the tree and it grew around it. Luckily I was sawing slabs 2.5" thick slabs and got some awful blue stain, put on heavily abused blade to remove slab from log (in case, I didn't cut deep enough), luckily missed dug out post later.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #11 on: June 25, 2014, 05:36:52 PM »
Found a 'possum living in a log on the log deck. But I am not sure it should ever really been called a saw log.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: June 25, 2014, 07:08:13 PM »
I am sure that most of you have seen my T fence post that was ~45' up the tree.
The customer gave me the block as a souvenir.
The tree was felled across a fence which drove the post into the tree.  The post broke off below the bark when the tree length log was skidded out.
Offline samandothers
« Reply #13 on: June 25, 2014, 10:07:06 PM »
Mikey
If that Hot Wheel was one manufactured in the late 60's with redlines on the tires and in good shape you could sell for good money!  Amazing what some of those old redline Hot Wheels will go for.
Offline Bogue Chitto
« Reply #14 on: June 25, 2014, 10:38:45 PM »
Cutting a sinker cypress.  Out comes a snake.
« Reply #15 on: June 26, 2014, 11:19:10 AM »
We get scorpions and lizards wintering inside our mesquite logs. Sometimes hundreds of them. :snowball:
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #16 on: June 27, 2014, 06:54:11 PM »
     That's not unusual.  Around here, if there's a hole in a log there's gonna be some kind of livestock living in it. :D  It's usually something I'd rather not grab, too.
WoodMizer LT50HDD51-WR
Lucas DSM
Offline reswire
« Reply #17 on: June 29, 2014, 09:05:59 PM »
I cut down a large maple on my property that was planted in about 1910.  In the middle of the log was a 3 foot long piece of metal, about 3 inches across.   It was probably placed there to keep the tree growing straight, and the tree simply grew around the metal.  When we cut down the tree, it stopped a brand new 660 stihl dead in it's tracks.   Blew the cylinder head I was told.  we did get some really pretty boards out of the log, of course after cutting around the chunk of steel.  One old guy who lives by me, said the metal was a leaf spring off of an old ford.  Who knows??? ;D
LT 40HDG 35, JD 5205, some Stihl saws, 15 goats, 10 chickens, 3 Chessies and a Weiner dog...
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #18 on: June 29, 2014, 09:17:58 PM »
I found half a mouse in a log once.  I went back and checked the previous board and found the other half.    :D
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40 Super- Wide HDG38
Lucas Dedicated 60" Slabber
Offline ohsoloco
  • Can we stay outside and play in the sawdust?
« Reply #19 on: June 30, 2014, 09:58:08 AM »
I've hit all sorts of tramp metal, ceramic insulators, etc.  The most unusual one was when I was cutting a backyard walnut and when I opened up a void in the log I saw something brightly colored.  At first I thought it was some funky mold or fungus, but it turned out to be a plastic Easter egg with the remains of a chocolate candy in it.  I went to school with this customer's kids, so I knew it was in there for quite a few years.
question
Unusual varmint found sleeping on log pile, Please help identfy
Started by woodbowl on General Board
Last post February 03, 2006, 07:54:46 PM
by Slabs
My first foreign object!
Started by ND rancher on Sawmills and Milling
Last post February 10, 2013, 07:25:19 PM
by hamish
Unknown object question
Started by Jim_Rogers on General Board
Last post May 20, 2019, 12:55:37 PM
by Old Greenhorn
Most unique foreign object.
Started by Clevelander on Sawmills and Milling
Last post January 30, 2018, 08:26:48 PM
by Bay Beagle
