Author Topic: Kiln door?  (Read 1292 times)
Offline WoodChucker
    • The WoodChucker
Kiln door?
« on: July 19, 2004, 01:33:51 AM »
When I made my kiln doors today I forgot to put the plastic vapor barrier in one of the doors. Is this a big deal and is there anything I could do to it that would help? Thanks!
R.T.
If a Husband & Wife are alone in the forrest fighting and no one is around to hear them, is he still wrong anyway?
Offline Don_Lewis
  • dry kilns, heat pumps
    • nyle
Re: Kiln door?
« Reply #1 on: July 20, 2004, 02:32:54 PM »
Depends. How was it insulated?
Offline WoodChucker
    • The WoodChucker
Re: Kiln door?
« Reply #2 on: July 20, 2004, 03:29:54 PM »
Hi Don, it has 3 inches of the Super Tuff R, I think thats what they call it, anyway it's the good stuff, inside the 2X4 studs and I left a 1/2" air space with holes top and bottom to help the air circulate. Then I have 1.5 inches of the blue foam and another 1/2" of that Super Tuff R on the inside face of the doors. Then the 1/2" CDX plywood covered with aluminum paint on the inside. Just a little over R-30. I used a VB on everything else, even the other door, but I forget it when I made the first door, think I should do anything about it, or will it be ok? Thanks!
R.T.
Offline GF
Re: Kiln door?
« Reply #3 on: July 21, 2004, 06:55:40 AM »
Most of the time the insulation board will have vapor barriers of some type on them.  Even the pink and blue board have a thin layer of clear on them for the vapor barrier.  You may go there the manufacturers website and in the past I have even called them about this type of question.
Offline Don_Lewis
    • nyle
Re: Kiln door?
« Reply #4 on: July 21, 2004, 03:44:58 PM »
You should be okay with it as it is. The poly usually gets so poked with nail holes, it is only partially effective. Worth doing because it is cheap but it would not be worth taking it apart to add it.
Offline WoodChucker
    • The WoodChucker
Re: Kiln door?
« Reply #5 on: July 21, 2004, 06:11:09 PM »
OK, thanks for the info guys, glad to hear it will be ok the way it is. Now if the rain ever stops I might get it done. :)
R.T.
Kiln door for Nyle
Started by brdmkr on Drying and Processing
Last post August 30, 2008, 11:41:37 PM
by brdmkr
kiln door seal
Started by kelLOGg on Drying and Processing
Last post December 25, 2011, 08:58:35 PM
by Handy Andy
Kiln door hinges & latches
Started by D6c on Drying and Processing
Last post June 09, 2019, 06:02:27 AM
by jimbarry
Solar Kiln - Door Construction
Started by CedarDude on Drying and Processing
Last post November 28, 2015, 06:41:22 PM
by 2StateTrigger
