We have contest winners!
I will have to check the pads in a day or two. I charged the battery good today and it is good. also found this wiring issue in the box beside the battery. The grey wire between the two lugs does not look like it should be there. Looks like they tried to bypass something. Any idea what is going on here? (Image hidden from quote, click to view.)
Quote from: flatrock58 on August 19, 2014, 10:37:03 PM I will have to check the pads in a day or two. I charged the battery good today and it is good. also found this wiring issue in the box beside the battery. The grey wire between the two lugs does not look like it should be there. Looks like they tried to bypass something. Any idea what is going on here? (Image hidden from quote, click to view.)Looks like someone shunted across the solenoid that feeds the hydraulic box. Just means the hydraulics have power even when the ignition key is off...shouldn't cause any problems.
Started by Jwswan on Sawmills and Milling
Started by maple flats on For Sale
Started by geraldhale on Sawmills and Milling
Started by chet on Sawmills and Milling
