Author Topic: Battery Voltage 0 Controller Voltage 13.5 Accuset error  (Read 578 times)
Offline just_sawing
  • Making Split Rails Shingles and Sawing
« on: August 22, 2014, 07:31:07 AM »
I had my mill go down last night at the fair and will troubleshoot it today but I am trying to get a head start before I go to it.
 The accuset got an error and when I went to Diagnostics it showed the battery voltage as zero then went to 10 Volts as I watched. THe Controller voltage was 13.5. The battery is fully charged and the mill started OK. the Hydraulics have also gone wonkie not wanting to work all the time. I am headed back to the Fair 38 miles away and will get on the phone with WM, but my question is when the Accuset is showing voltage what is it looking at? Voltage to the accuset, Voltage to the machine?
You can follow me at
www.http://haneyfamilysawmill.com
Offline just_sawing
Re: Battery Voltage 0 Controller Voltage 13.5 Accuset error
« Reply #1 on: August 22, 2014, 07:35:39 AM »
One of the other symptoms is the Drive seems to stall out.
Offline drobertson
« Reply #2 on: August 22, 2014, 07:51:13 AM »
I believe it is the voltage going to the h bridge, if the battery is full, it could be a loose connection or,,,hate to say,
Offline just_sawing
« Reply #3 on: August 23, 2014, 08:29:01 AM »
Got with WM and talked to them before I drove out to the mill. The key was that the Mill head and drive still worked. That means that the line to the Accuset of a ground. We had suffered from a deluge of rain before so I went after the ground and found that the grounds had white corrosion a little. The problem was that the machine was working OK at that time. I put everything back together and started it to have a constant ERROR. Went beck to the drawing board talked to RON at WM and he basically said it is the line. I traced it from one end to the other and then noticed that when I cleaned the ground a Den Plug on top of the H bridge had fallen off. THe problem was a loose plug and it finally fell off. Put it back on and all is well.
Thank you Woodmizer for the best customer service that I have every seen. This is a high compliment for me since my other hat is a consultant.
High Voltage!
Started by 4x4American on Sawmills and Milling
Last post October 05, 2015, 08:06:12 PM
by Kbeitz
voltage/electricity
Started by bedway on General Board
Last post November 20, 2007, 10:18:46 PM
by oldsaw
Voltage gage
Started by Chuck White on Sawmills and Milling
Last post March 08, 2009, 03:39:07 PM
by Chuck White
Woodmizer voltage drop
Started by bandmiller2 on Sawmills and Milling
Last post February 22, 2011, 02:14:24 PM
by sparks
