Pitch / Sap removal tip for my fellow sawyers
Started by golddredger, September 02, 2014, 04:08:32 PM
golddredger
Good afternoon. Thought I would share a tip that was told to me when I was a kid sawing digger pine for fire wood with my dad. The old timer logger told me to use mayonnaise to get the pitch off. When I got home I tried it and it works a treat! Over the years I have found that Best Foods mayo works best. I been milling pine the last few weeks and even with gloves I some how get it on my hands and arms. The mayo goes on straight from the jar rub it in. Makes a stinky smell but breaks the pitch sap down in a flash. So I thought I would share this tip as it was shared with me 30 years ago and I still use it today. Good milling to all!
Home built bandsaw mill and trailer for a mini logging operation. Lots of chainsaws and love the woods.
GAmillworker
Thanks for the tip.
Maybe now I can at least like mayo for a hand cleaner.
Thank the Lord for second chances
kelLOGg
Quote from: GAmillworker on September 02, 2014, 05:11:59 PM
Thanks for the tip.
That's the best use for it I can think of. (not a fan of eating mayo)
Bob
backwoods sawyer
That is because you have not been putting on Grits ;D
Heard about Mayo a long time ago as well :P
Grits and Mayo hand cleaner ::)
Backwoods Custom Milling Inc.
barbender
kelLOGg
Quote from: backwoods sawyer on September 02, 2014, 11:06:24 PM
:D :D :D :D :D  That's a southerner's version of Lava soap. Great idea. It would sell all over the south. ;D
terrifictimbersllc
You're going to have possums in your sawdust.  Might as well cook them up too.  :)
4x4American
Thanks for the tip!  Now I can stop using gasoline...
Boy, back in my day..
golddredger
Give it a try I promise you guys will be amazed. Just rub it in. I use my fingernail and it takes it right off after just a few mooments with mayo on it. Happy milling!
ST Ranch
Butter actually works as well, probably a bit more pricy and not as smelly.
LT40G28 with mods,  Komatsu D37E crawler,
873 Bobcat with CWS log grapple,
POSTON WIDEHEAD
Forget the hands.  Slice and fry the grits and all that you need is bread and you will have a sammich.
Delawhere Jack
But what if you've got just enough mayo to either put some on a BLT sandwich or clean your hands........ :o
I'm going with eating the BLT with dirty paws. Y'all can kiss my grits. ;D
POSTON WIDEHEAD
I've ordered 5 gallons for my lube tank. Pure Mayo when sawing Long Leaf Pine.  :o
junkyard warrior
Quote from: ST Ranch on September 03, 2014, 06:57:06 PM
side note.....butter also works for roofing tar
hey willbur and orville.......that will never work
woodweasel
Heck bring some bologna and a loaf of bread & there you are 8)
DMcCoy
I will have to try it.  I always use WD40 to cut the pitch and then gojo to remover the WD.
UpInATree
Being a tree climber I get my hands and arms smothered in pitch sometimes.  I have found that 91% Isopropal Rubbing Alcohol is my miracle cure.  I buy it at CVS in the quart bottles and just drizzle it onto my arms when I get down from a pine tree.  Rub and wipe off with a towel or rag.  The alcohol cuts right through the pitch, then it evaporates off your skin without any smelly residue to clean off!  BONUS...if you are working near poison ivy, it takes all that poison oil off your skin too.  When I have to climb trees with poison ivy vines, I wash my arms and face right after I get down and I don't get any more rashes from it.
Remember the 91%....not the 70% strength....works great.  I hate mayonaise
Wood-mizer LT70HD D55 Wireless, Wood-Mizer ED-26, A whole bunch of Stihls. Alaskan Mill 74",  Bucket Truck, Log Truck, Chippers, trailers, dump trucks,   Kubota M9540, L3010D and B7510. Cord King.   Learning Timberframing under Jim Rogers
gimpy
Or you can put 2 tablespoons of Dawn soap and half a cup of Pine-Sol in your water bottle and it keeps the problem from occurring. Just a thought to save the Mayo for those BLTs.
Use the (91%) alcohol on my hands.
Gimpy old man
Lucky to have a great wife
John Deere 210LE tractor w/Gannon Box
Barney II
I have always used lacquer thinner to remove pitch-------you don't suppose that lacquer thinner is in mayo  :D :D :D :D :D :D :D :D :P :P
Ya never know
Woodmizer  1985 lt30
goose63
Whats amatter wit mao and GRITS? I likes em both
goose
thank you to all the vets
fstedy
I run pinesol and water but you still get patches of resin and sawdust buildup on the blade ( cut a lot of pitch pine around here very resinous ). When that happens just idle the blade and hold a knife on the blade to clean it off. The knife I use is made from a edge sharpened piece of old sawblade with a handle taped on it.
Timberking B-20   Retired and enjoying every minute of it.
Former occupations Electrical Lineman, Airline Pilot, Owner operator of Machine Shop, Slot Machine Technician and Sawmill Operator.
I know its a long story!!!
Chuck White
I do that once in a while too fstedy, just make sure the blade is slow, but mainly just be careful.
golddredger
Not sure how this thread got off track but he the mayo tip is to clean pitch off your hands and arms. NOT your mill or blade as lube. Pretty ovious I thought in my first post. Just read some (Admin language edit) comments in another thread about using mayo for sawing.... Last time I share a tip here. Did I take it personal......? Yes  :o
That's a tough one if you took it personal.  cheers
And if it is a good tip, then in time others will try it when they have the need and have a jar of mayo handy.
Probably will be done on the sly until it proves to work, and they will tout it to others as a good tip.
In the interim, we just havin some fun.   8)
