Can't ID This Thorn Bush
Started by g_man, September 15, 2014, 04:34:20 PM
g_man
We have an old cellar hole and I found a small clump of thorn bushes near it. I guess that means it could be anything. What ever it is it seems to be pretty shade tolerant. What is this ???  It is in northern VT.  Thanks
CJennings
BradMarks
BradMarks
CJennings
I should of added to my other post, I hope you don't have any valuable white pines close to those plants. Ribes spp. are required by the fungus responsible for white pine blister rust.
g_man
Quote from: CJennings on September 15, 2014, 07:29:10 PM
Hmmm............ I have a lot of pine but don't have much that is valuble because of weevil and blister rust.
There must be more of those bushes around even though I have not noticed them. I have blister rusted pine a quarter mile in any direction from that clump of bushes.
Thank you very much for the ID guys !!!
g_man
I should add - What is the best way to kill it ?
curdog
Roundup or 2-4D would probably be the cheapest options.  I'm sure most broadleaf herbicides would work.
I have had very good luck with Pronto,Big'n'Tuff from tractor supply. Much,much cheaper.
VT_Forestry
Quote from: thecfarm on September 16, 2014, 05:22:27 AM
That's good stuff, kills most anything and for the price you can't beat it  :)
Forester - Newport News Waterworks
curdog
Yeah you're right, I spray the generic from tractor supply as well. I can't remember the name,  but it's a 41% solution of gly.
g_man
This clump is small enough that I could easily pull it up. Considering the time of year is spray the best option.
I have some 25% gly, it sounds like that may not be strong enough. I'll get some of the stuff Mr C-farm suggested - Thanks
Pull it up, and spray next year if any comes back. Best to spray when there are green and growing leaves. They may be dormant already this time of year. And 25% gly would likely work, just take a bit longer to see the results. IMO
I try to buy it on sale,Pronto. I brought some last year,about $40 for 2½ gallons. I do find this stuff does not work as fast as round up. But I feel it works as good. Round up takes 3-4 days to see it working,pronto takes about twice as long to see results. But even if I had to use twice as much,it would still be way cheaper. Can't even buy a ½ gallon of total vegation killer round up for $40. Last time I checked a quart was $26.
Chuck White
Pull it and throw it in the backyard fire-pit!
mesquite buckeye
g_man
Quote from: Chuck White on September 16, 2014, 09:18:34 PM
That is exactly what I did yesterday. Filled the wagon I pull behind the ATV with the stuff.
