Author Topic: Sawmill shed  (Read 6667 times)
Offline mhasel
Sawmill shed
« on: October 07, 2014, 09:52:31 PM »
Need some advice on shed layout for a woodmizer, photos a plus:)
Would like to do a semi enclosed with wide doors on either end for loading and two side doors for trailer or skidding logs into if necessary, maybe 32x52
Thanks in advance would really like to know what has worked well and what you would change if you had the chance
Mike
Offline highleadtimber16
  • Learning Everyday
Re: Sawmill shed
« Reply #1 on: October 07, 2014, 10:13:29 PM »
This probably isn't what you're looking for, but gives you an idea!  :)
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Online beenthere
Re: Sawmill shed
« Reply #2 on: October 07, 2014, 11:30:43 PM »
highlead
That's a sharp looking shed there.
mhasel
Add your location to your bio in your profile, and it may help a lot with recommendations.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Sawmill shed
« Reply #3 on: October 08, 2014, 07:40:10 AM »
That size would be fine as long as you do not plan to dry or store lumber in it.  If you are, I would consider making it larger.
Offline New Brunswick
  • Sawmiller's sharper than most.
Re: Sawmill shed
« Reply #4 on: October 10, 2014, 04:31:24 AM »
I read here that the size of your shed should be measured in acres not feet haha..I have been building a shed this year 28x54. It is not finished yet, but now sawing inside of it, and really enjoying the roof. I made a exhaust chimney through the roof that I hooked a rubber exhaust hose too, and it works really well for getting rid of the fumes, as I did try milling inside without the siding on and realized the fumes were going to be an issue...something to think about.
Offline Farmer Jim
Re: Sawmill shed
« Reply #5 on: October 10, 2014, 04:47:41 AM »
Very nice shed.  What is the length of opening on the left side of the photo?
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them."  J.B.Books
Offline jrose1970
  • Feller = One who fells trees.
Re: Sawmill shed
« Reply #6 on: October 10, 2014, 08:08:28 AM »
That is a good question about the best sawmill shed. I'm all ears.
HFE-36; International 424-37HP; McCullogh Pro 10-10
Offline drobertson
Re: Sawmill shed
« Reply #7 on: October 10, 2014, 08:51:56 AM »
This is not the best shed by far, but works for me,  I would change a few things, skylights,  and bigger doors, two on the ends work fine for the drive through, the west door could be bigger than 12' the log deck works at 20'
Offline wwsjr
  • Think Orange
Re: Sawmill shed
« Reply #8 on: October 10, 2014, 06:40:30 PM »
Mine is a simple built 12 X 40 shed. Weather is not a real factor for me in the south. The opening for logs is 30', used an old steel bar joint joist for support. Office/tool/blade/electrical panel shed, 12'X12' is on the end.
Retired US Army, Full Time Sawyer since 2001. 2013 LT40HD Super with 25HP 3 Phase, Command Control with Accuset2. ED26 WM Edger, Ford 3930 w/FEL, Prentice Log Loader. Stihl 311, 170 & Logrite Canthooks. WM Million BF Club Member.
Offline Knute
Re: Sawmill shed
« Reply #9 on: October 10, 2014, 08:34:55 PM »
drobertson,
Is that  a D-14 I see? Those old AC are great tractors.
Offline drobertson
Re: Sawmill shed
« Reply #10 on: October 10, 2014, 08:59:47 PM »
D12 series 3  28hp at the wheels and 25 at the pto  a fine lil tractor. needs brakes though,
Offline mhasel
Re: Sawmill shed
« Reply #11 on: October 10, 2014, 09:20:52 PM »
Awesome folks, please keep the photos and ideas coming, I've gotten quite a few already like the rack for the flicks, always just set the loader there and loaded onto the forks but this makes more sense
wwsjr, what type of blower are you using for sawdust there, very nice clean setup, plenty of access all around and very neat, I'd have to put some door on it to try and keep the weather out here in MD thought. Even the little details like log chocks are a + little things that make sawmill life easier.
Offline wwsjr
  • Think Orange
Re: Sawmill shed
« Reply #12 on: October 11, 2014, 08:39:49 AM »
mhasel,
The blower is a cheap Harbor Freight 2hp, not good enough for most sawing. I have a 3-phase, 3hp I plan to get installed soon. After my mill and shed burned last year, I tried to go cheap on blower, won't handle wet SYP dust. Will move to my planer in shop later.
  • Learning Everyday
Re: Sawmill shed
« Reply #13 on: October 11, 2014, 11:37:29 AM »
If you're referring to the side of which the logs are loaded, I think it's 22 feet.
Offline Banjo picker
Re: Sawmill shed
« Reply #14 on: October 11, 2014, 05:14:15 PM »
wwsjr done good with that 30' opening.  Mine is only 21' and that ain't enough.  I can cut 24' and can worm them in but it is not easy...If I was doing mine over again I would want a nice large opening on the loading side of the shed and another on the unloading side.... its worse getting 21' plus out than it is getting the log in.... I'll remedy that by adding enough roller tables to one day just roll the long lumber out the end of the shed.  Nice looking bld. there wwsjr.  Banjo
Offline Farmer Jim
Re: Sawmill shed
« Reply #15 on: October 12, 2014, 03:41:40 AM »
Yes, the log side, thank you. What are the dimensions on the beam that spans that side?  I need a shed also.  Only being able to cut on good weather days cuts into other things that need to be done on those days.  I can cut 21' and change so that opening would work for me. Thanks again.
  • Learning Everyday
Re: Sawmill shed
« Reply #16 on: October 12, 2014, 06:05:33 PM »
6x12 beams on 8x8 posts all fir. The knees are 4x10.
  • Learning Everyday
Re: Sawmill shed
« Reply #17 on: October 12, 2014, 06:08:41 PM »
Here's a side view, though it's a little blurry.
Offline Farmer Jim
Re: Sawmill shed
« Reply #18 on: October 12, 2014, 06:53:47 PM »
Thank you. That is a big help.  Now I just need a shorter "To Do" list.
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Sawmill shed
« Reply #19 on: October 13, 2014, 06:53:12 AM »
Mine with a 45' door 24'x85' and on the right of the pic will be a 18'x80' for lumber.
A&P saw Mill LLC.
License NH softwood grader.
Sawmill Shed
Started by bigD on Sawmills and Milling
Last post March 06, 2015, 08:50:05 AM
by bigD
Sawmill Shed
Started by Junior437t on General Board
Last post May 29, 2005, 04:30:25 AM
by Bibbyman
first Sawmill shed
Started by Florida boy on Sawmills and Milling
Last post June 17, 2017, 10:15:21 AM
by woodworker9
Sawmill Shed
Started by stanwelch on Sawmills and Milling
Last post August 01, 2016, 03:07:39 PM
by Czech_Made
