What if you spray some soap solution on logs? Would it keep the bugs off?
Started by StimW, October 17, 2014, 12:33:01 PM
StimW
I have some pine logs that I don't know how soon I will be milling and I was wondering if a soap solution would deter bugs?
I have them off of the ground but am already getting white caterpillar looking bugs under the bark.
New HF Band Mill
Branson 35 hp 4 WD Diesel Tractor W/Attachments- Backhoe, FEL W/ Bucket or Forks, 4' Tiller
4000# Clark Forklift W/24" Tires
Promark 6" Brush chipper W/18 hp Kohler
drobertson
Not sure if it will keep them off, but it would kill what's there,  I would try to get the bark off all the logs and then kill what you see.   They will keep on boring until they are removed.
36 coupe
You better mill those logs now unless you want boards with holes in them.
Chuck White
I agree, keep the logs up off the ground and remove the bark and it should end the bugs!
Two years ago, I sawed 2 huge White Pine logs that were peeled and were up off the ground about 10-12 inches and there were no bugs and the logs were as sound as fresh cut logs!
Stim, You will at least have clean little bugs. Soap will help but peeling the bark will work better. Frank C.
