CB 6048 water test help
Started by Kemper, October 19, 2014, 08:30:12 PM
Kemper
Can anyone explain to me how to use the test kit provided or an easier way to check water to make sure it's not to acidic? I think the owners manual does an extremely poor job of explaining this process or I'm not smart enough to comprehend. Thanks in advance.
sharp edge
I don't understand. Explain more.
SE
The stroke of a pen is mighter than the stroke of a sword, but we like pictures.
91' escort powered A-14 belsaw, JD 350-c cat with jamer and dray, 12" powermatic planer
Kemper
I'm not smart enough to do the water test with the test kit provided. If someone could put it laymens terms or explain another way to test the wartervto keep steel from corroding.
Quote from: sharp edge on October 19, 2014, 10:03:29 PM
SE
wishiwasfishingguy
Your dealer should be able to show you how to do this test.  Can you bring a water sample to them?
David-L
All it is , litmus paper and the acid drops, then the color chart.. Follow the directions to the tee and after a few times you will have it down. What about on you tube, maybe a post there to explain.
