Set carb with or with out bar & chain?
Started by Timberwerks, August 01, 2004, 07:00:37 PM
Timberwerks
Should I be setting the carbs on my saws with the bar and chain or with out? ???
DanManofStihl
I always set my carb with the bar so the chain won't run and it will still idle.
Two Things in life to be proud of a good wife and a good saw.
tony_marks
 depends on the saw for me.. if its one with the power to do heavy cutting.. i set it in heavy cut..rpm dont mean nothin unless it ll hold a good rpm in cut.. jmo
sawguy21
I always set thecarb with chain on. Gives me a better feel for idle and throttle response. Once, I was setting up a Homelite, I believe an XL-12, without the bar, chain, or cover. I was (foolishly) pinning it up then down when BANG and there were clutch parts flying everywhere. The screw on rotor decided it had had enough and was leaving. A shoe was embedded in the drywall and I never did find the springs. Never did that again
