pumps
Started by snowstorm, December 15, 2014, 06:15:50 PM
snowstorm
i had a little melt down today with my owb . some how it got hot enought to melt the pex along with the 2 pumps. i think they were taco 009. the tag is burned off and the wiring. the pump to the house is 100ft and up 8ft. and wil be running up to 4 007 pumps. the one to the garage is 20ft and up 10ft and runs to 2 modine heaters
r.man
Hope your stove is ok. I had mine empty of water to do something, forgot and in early fall lit it to burn off leaves etc from the yard. Melted off both lines but my pump is in the basement. Cost me a bit of work and pipe but nothing major.
Dave Shepard
If you google pictures of 007 and 009 pumps, you will see there is a difference in the motor. An 007 has a smooth, straight barrel, and an 009 has a tapered motor with "fins" on it. I don't know what an 011 looks like, other than it's noticeably bigger. I had a boil over on my OWB when the damper didn't close. That was a bit scary, but I don't think it cooked off too much water.
snowstorm
the 009 is much bigger than the 007. the 009 says 35' of head and 10gpm.   0011 is 31 head and 31gpn. i will call taylor they built the stove and see what they think
Holmes
 200' of 1" pex is 12 ft of head.  10 gpm will give you 100,000 btu's per hour.  I believe you would need an 0011.  The 007 pumps will do the work to heat inside.
Think like a farmer.
snowstorm
Quote from: Holmes on December 15, 2014, 07:48:38 PM
so you you think the 0011 would be better than the 009? how many btu with the 011?
Holmes
The 0011 will deliver 200,000 btu  the 009 will deliver 80,000 btu.  How big is your house sq.'?
snowstorm
1700 on the ground floor. its a cedar log cabin with a 17' ceiling on one end. with in floor heat
Holmes
 80,000 btu will heat the house easily but the garage may make 80,000 btu marginal.
snowstorm
the garage is 40x40 14 high it heats easier than the house
Holmes
The garage should be harder to heat than the house.  Is it all spray foamed?       You are in Maine ,I would go with the 0011.  You will know the btu's are getting to the house and garage.
snowstorm
ok thanks i will see if i can find 2 0011
Dave Shepard
Do your homework. I found 009s for $179 shipped online. My plumber's cost locally was $236, and they weren't in stock.
Holmes
Up until about 8 years ago the plumbing supply house was a great asset for plumbers, now they are not.  It is cheaper for me to buy many items at home depot or lowes.  The service and knowledge base has disappeared from the supply house.  We get less and pay more.
Coming to Jay? Memco should would have them in stock. I brought some from him.
snowstorm
bought 2 today/ $207 each everyone else wanted $325
Dave Shepard
