Whatcha Sawin' ???
Started by Magicman, December 23, 2014, 12:00:38 PM
0 Members and 6 Guests are viewing this topic.
E-Tex
Mantel Day today.  cut 4 mantles for two different customers that dropped off logs.
1.  Pine:  11½ x 8¼ x 6ft
2.  Pine:  12"  x  9½  x 6ft  -  live edge
3.  Cedar:  "Quartered Look" - two
LT-50 Wide, Nyle 200Pro Kiln, Mahindra 6065, Kubota 97-2 / Forestry Mulcher
L2 Sawmill LLC
Peter Drouin
Sawyer ted, why would have to use the chain thing with a loader like that on the job?
A&P saw Mill LLC.
License NH softwood grader.
SawyerTed
Peter, i understand why you are asking.  I got the log loaded on the mill but it had a little sweep and it was too heavy to roll the last little bit with a cant hook.  I just needed it to roll a quarter turn-just far enough for the clamp to catch it.
I'm a little hesitant to use the big loader to load logs.  My skills with it aren't real good yet.  I've only been using it a couple of weeks.
I like those mantels Lance and I really like the ERC ones.  8)
Peter Drouin
looks a little tight to the header of the building too. One mistake with the loader will not be good for the mill. :D ;)
I use the loader on the mill to load logs. The only time I put a log on the mill with the Cat is when I'm over 20'.
But, I'm going to start using straps to [set] the log on instead of rolling it on.
A&P saw Mill LLC.
caveman
SawyerTed, you did not catch that snook (racing mullet) in NC did you?  It has been too wet to saw here.  Sawn boards would mold within hours.
Caveman
Almost looks like water on the ground. ;D
dustintheblood
Quote from: Bruno of NH on August 28, 2018, 08:07:32 PM
We had 100° with the heat index in NH today.
Milled till noon then cut firewood.
Falls coming  :)
Up here in Canada we start doing firewood on the 20th of July and don't stop until the 19th of July.
Case 75C, Case 1494, RangeRoad RR10T36, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln
caveman
Lynn, That is water on the ground and it has been there for about six weeks.  I caught a crawdad walking around outside my shop on Saturday morning.  We have had tadpoles swimming across the driveway for weeks.  I am not complaining because we have dealt with dry times in the past but it has been damp here lately.
Caveman
YellowHammer
That's a lot of water, enough for the logs to float off.  :D
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Brad_bb
I haven't sawn it yet, but I think this Cherry is going to be a good 'un!  It's about 14 at the small end if I remember right.  I could make some timberframe braces or?
SawyerTed
Quote from: caveman on August 29, 2018, 09:52:24 PM
The snook came from St Lucie Inlet
It was wet in Salerno. We fished three days between rain storms. It was really wet there too!
Water Dogs
    Got a call form a tree guy free logs just haul them off he will load them. I hate to see them go to the shredder did see some nails that so all will be scanned.
MobileSawMilSlo
Hi guys
On Wednesday I change rollers and did full re-alignment of the sawmill ... blade wheels, complete head, without rollers, with rollers etc.
Yesterday I did the test and I tool old dry spruce and cut several 4mm and 2mm slices.
It looks that alignment is OK and everything has been done right.
Woodmizer LT20 mobile and TTP-600 Premium Plus
DAJK - all sawing equipment in one place
Yes it gives you a good feeling and is also a confidence builder when everything checks out. smiley_thumbsup
My today was nothing but Honey Locust, yes the thorny kind. :o
Turned out some purdy stuff.
More.  :)
Sawed a live edge/face mantel.  This may be the first time that I have taken an inch off of the bottom.
Say What??  :o  OK, load it up.
About 6 cookies off of the top fork before we got into the "log".  :)
Kinda nice cookies.  I brought two of them home with me.  :)
We also got these 9 live edged slabs.
And they were very nice.
Stacks of 1X8 & 1X10 Honey Locust plus live edged slabs and table legs.
One of the two Honey Locust slabs that he gave me for benches.
I thought that we would finish today but he "found" some Red Oak logs for Tuesday.
Busysawyer
Sawin up some firewood today.  Rented this bad boy for the holiday weekend. No rest this weekend for me.
Even a blind squirrel finds a nut every once in awhile
Dat's a serious machine. :o
Busysawyer
Mm, it works pretty darn well. Ran that pile you see in that pic in about 3 hours by myself.  It took a little bit to get used to the controls but after that it went pretty fast. Been thinking about renting it for awhile now, called them this morning and asked if they'd be willing to give me a deal on it over the holiday weekend and they obliged.
Lawg Dawg
RRRQSWO
load the log
Start de-slabbing it keeping the pith in line
Start pushing the half up and over the backstops and pulling down with the clamp at the same time, its tricky but doable
Find the embeded hardware
Lots of edging on the mill with no edger
Beautiful results! I'm hooked on this method! 8)
Here comes more WO!  :)
Oh yeah, I anchorseal after the boards are cut, so you can see the rings, thanks Yellowhammer for inventing this method!
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Looks like you were hitting the mark quite well.  8)
Southside
Dawg - a little silicone and that hardware will buff right out.... :D  :D  :D
White Oak Meadows
trapper
Got a call today fellow 25 miles away  I was recommended by a large lumber company whose rep I talked with at a trappers convention.  Customer had logs sawn before and sawyer cut everything live edge.  Customer wanted everything edged. He told me will not use that sawyer again.  told him I will cut whatever he wants. This year is the busiest I have been just being mostly A hobby sawyer.
Dawg,
You need an edger :)
Lawg Dawg
Quote from: Magicman on August 31, 2018, 10:41:00 PM
I think I did pretty good! Thanks
Quote from: Southside logger on August 31, 2018, 11:00:12 PM
I like to spray my fresh cut lumber with this stuff...keeps the bugs out of it! :D
Quote from: WDH on September 01, 2018, 07:51:04 AM
Dawg,
You need an edger :).
I sure do, but I can't get any more equipment till I get more ROOF!  Know what I mean :D
Pro Sawyer Network
