Clark parts
Started by stoneeaglefarm, April 20, 2015, 10:31:36 AM
stoneeaglefarm
Hi Folks, Have checked with several folks looking for service break parts for my 78 664b Clark and also assembly from transmission back to rear end. No luck with guys at Davco, Harolds of Maine one spot in virginia. Want to put this clark back together proper and get it working. Thanks.
treeslayer2003
what exactly do you need? brake parts may be scarce but drive line parts should be able to be sourced from truck drive line shops.
North River Energy
Check with these guys (you'll probably want to have the transmission model number handy):
http://www.minnpar.com
Also, the folks at General Gear in Idaho might know where to find what you need if they don't have something on hand.  They're mostly construction equipment, but have always been helpful:
http://tractorparts.com
nhlogga
Exactly what parts are you looking for?
Jonsered 2260
Husky 562xp
stoneeaglefarm
Looking for the service brake assembly parts, Also, Coming of the transmission back to the rear end am looking for the second part of the driveshaft and the bearing parts and parts that hold the bearing, that run back into the drive of the rear end. Thanks.
jdeere540a
have you tried pb&h equipment in Antrim they specialize in john deere but can get anything.  they got me a lot of parts for my 540a.
stoneeaglefarm
Yes sir, I am actually good friends with the guys up there and they are searching high and low for parts, I think we may have Brian and Kirk who works out of there make and or fabricate some stuff if we have no luck. Thanks, They are great guys to deal with.
