Is this poison ivy?
Started by Brad_bb, April 21, 2015, 09:27:46 PM
Brad_bb
Is this poison ivy (Northern IL)?
POSTON WIDEHEAD
Brad_bb
I've never had poison ivy in my life.  I'm buying some Walnut logs that may have some of this on it.  Any words of advice?
limbwood
samandothers
Don't touch the vines with you hands (or any other body part).
WV Sawmiller
If you burn the vines or leaves stay far away from the smoke. it concentrates the toxins and gets it in your eyes and lungs. Burned PI can be worse than the actual vine or leaf.
I just remove it with an axe, etc.
Brad_bb
Thanks everyone.  So MM you think I should take it off before milling as opposed to just slabbing with ivy and all?
sandsawmill14
also DO NOT BURN especially while its green until you know if/how bad allergic you are.  :)
fishpharmer
If you saw the vines, the sawdust can be nasty too.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Quote from: Brad_bb on April 21, 2015, 09:48:14 PM
Absolutely.
POSTON WIDEHEAD
Even if you take it off the log, I would wear a mask before sawing. If you've never had the rash before then you really don't know what your reaction will be. Better safe than sorry.  :)
If the leaves are 5 instead of 3, then it is virginia creeper.
I find the vines on the bark of both can be quite similar, although I'd guess this one to be PI too. For sure, until I learned otherwise.
Cutting through it with the chainsaw and getting the chips down your shirt collar will give you an itch.. I've found. ;)
Virginia Creeper and Poison Ivy attach to the tree completely differently.  VC has "legs" and PI has "hair".  The "hair" on the above pictured vine is a dead give away.
4x4American
Beenthere beat me to it.  I have also found that if you cut through the vines with a powersaw you best be careful where you're spitting them chips and oils.  Wash down equipment with dish soap.  Heck if I think I came close to ivy I'll shower with dish soap just to be safe.  The ivy's oils are what causes the rash and itching, and dish soap will dry it out and help.  Tecnu works good too.  I used to not get p.i. rashes, then all of a sudden I get it pretty easily.
Boy, back in my day..
I can agree with what MM says about the hairs and legs.  ;D
Also, on using the axe or tree loppers. I cut it at the ground, and use the axe to loosen it from the tree so the chainsaw doesn't cut through it. And still am careful where the chips fall from sawing through the log.
X2 for 4x4 comments. And washing soap and water all body parts within 2 hours of possible contact work for me. Always wash hands after tying the boot laces too. Wash clothes too.
Never used to get it, but now do if not real careful. Still need to work in and around it sometimes.
trapper
Ljohnsaw
I bought my cabin property about 1,000' higher than the poison oak grows (as bad as poison ivy) around here.  I didn't want to deal with it!  Went camping down on the coast over spring break - There were bushes of poison oak EVERYWHERE!  I just wanted to use a spray bottle of Round-Up on our hikes :D
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
YoungStump
Wash your hands before you use the bathroom! Don't ask how I know.
Echo Enterprises 45HD2 production series band mill, Cook's Edger, sawing mostly pallet cants, rr ties, and grade lumber.
Ron Wenrich
Sap is the big culprit in getting the rash.  Especially this time of year.  I don't get a rash very often.  When I do, it's when I rub up against fresh cut and I'm sweating.  But, I'm not very sensitive to poison ivy.  I can work in, pull it off logs, cut it in the brush, and not get more than an occasional rash.
When I was marking timber, I would sometimes wade through the stuff.  My wife would get poison just by washing my clothes.  She would also get it by just petting the goats we had at the the time.
If you're not sure if you get it our not, keep covered up.  When you're done, make sure you wash yourself down with a strong soap.  Showering is usually the best.  Wash your clothes right away.
Quote from: YoungStump on April 21, 2015, 11:12:38 PM
Youngstump, that is one of those body parts that I was referring to  :)
Goats consider poisoned ivy a fine salad green. Frank C.
I've never seen it in a vine here.   :o   On the edge of the woods I've seen it knee high,in the open not much more than a foot high.
"C", you must be at the northern edge of its range, down here it will take to the trees, its a constant battle. I always take a pair of loppers and remove several inches of vine, that puts the bind on the top leaves. In my youth I caught it easily , now I have to really abuse it to get the itch. Tollerance will vary some folks don't get it others just have to look at it. Frank C.
