Sawmill Shed
Started by stanwelch, May 11, 2015, 09:22:48 PM
I see square corners and sides that are plumb! Isn't that a crime against nature?
Looking real good. I am sure you will get many years of service and pleasure out of this structure. Keep the pictures coming.
Jim_Rogers
Quote from: WV Sawmiller on July 16, 2015, 08:33:46 AM
No that's the timber framing way of things.....
Jim Rogers
stanwelch
I made a lot of mistakes building this frame which I acknowledge and can expect from a novice without any training and experience. However, I was impressed how well the bents stood square and plumb by themselves.  When I measured after all four bents were secured, the frame was within 1/4" over 30 feet.  I said "close enough"
Woodworker, Woodmizer LT15, Stihl 026, MS261CM and 460 chainsaws, John Deere 5410 Tractor 540 Loader,Forks & Grapple, Econoline 6 ton tilt bed trailer
stanwelch
I'll be working on the roof deck next. I'm using red oak and cottonwood boards milled to 7/8 thick. Width varies from 8" to 6" by the 1/2 inch. I plan to use the same width the lengthwise on a row. I plan to start from the lower right corner (SE) above the sawmill. Oak boards will be placed first on the lower rows and then cottonwood on the upper half. I may use oak at the top few rows depending on my board count.  I plan to align the starter row to overhang the rafter end by 1 1/2" and the gable end by 1 1/2 also.
Is this a good plan?  I have not done this before. Any advice/suggestions are welcome  :)
Finn1903
Quote from: stanwelch on July 17, 2015, 07:33:17 AM
My father would say your frame is built like a rocket launch platform.
WM LT40HDD47, bunch of saws, tractor, backhoe, and a loving wife.
Jim_Rogers
Quote from: stanwelch on July 17, 2015, 08:42:21 AM
Good plan but check alignments every so often. Just in case you start to gain on one end. And compensate for that by checking your lumber and see if you have some which are a bit narrower, and use them on the end that gains. Or rip one to remove the gain and start straight again. A small gain shouldn't be noticeable from underneath when all done.
Jim Rogers
stanwelch
Good start on the roof today. We should finish tomorrow. Shade is a good thing  :)
Looks good but be careful.  We do not need another of us broken up.
Stan,
You are doing just a fine job on that shed  8).
snowshoveler
Sawmill shed...
No way, thats built better and better looking than a lot of houses I have seen.
Nice job...when you get done with that 1...I have a little job for you.
Regards Chris
International T5 dozer
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
stanwelch
Thanks guys.
Magic - with age comes wisdom. I'm doing the ground work and have hired two young Amish men to do the elevation work much easier on the knees and back  ;D
Peter Drouin
Now that right there is a nice mill shed. 8) 8) 8) 8) Good job.
drobertson
Looks absolutely fantastic,,
Percy
Very nice..... well done!!!
stanwelch
Finished the roof Yesterday morning. Two and a half Amish men 10.5 hours to install 200 deck boards and all the metal. They did an excellent job.
LT 15 is in the shade and dry. Happy Happy Happy  8) 8)
deadfall
So nice.
Two foreign concepts there.  Cover and level ground.  I can't imagine.
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
brendonv
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
samandothers
The shed turned out great.  Now the mill will likely stay orange versus turning pinkish.
Excellent !!!  The Logrite looks happy too.   ;D
deadfall
Quote from: Magicman on August 22, 2015, 05:06:35 PM
I had to search a while to spot it.
Yup, it is visible in two of the pictures.   ;D
The sticker rack is happy, too  ;D.
I see that Jim Rogers' sawdust bucket is alive and well.   ;D
Dave Shepard
I tried to use a bucket once, but I would need a 20 gallon bucket for what I saw. :D That is a really nice sawmill shed. :)
Quote from: Dave Shepard on August 22, 2015, 08:42:49 PMI tried to use a bucket once, but I would need a 20 gallon bucket for what I saw.
Didn't work for me either, but of course I am not sawing in a shed and always leave the sawdust at the customer's location.  That plus the slabs and lumber.   ;D
