Clean up
Started by Peter Drouin, August 17, 2015, 09:06:03 PM
Peter Drouin
I was going to put a vac setup for the sawdust, But when it gets cold I'll be doing this anyhow. So I will use John, Only takes ½hr or so and I still need to sweep under the mill even with a vac.
A&P saw Mill LLC.
License NH softwood grader.
The life of a primarily stationary sawyer.   ;D
He can't just saws em and leaves em.
Chuck White
A leaf blower would help too!  ;)
petefrom bearswamp
As my avatar shows my shed is narrow so most sawdust ends up outside as I only lower the sawdust hose when the wind is really a nuisance .
I only have to move it about once a month.
Mill cleanup is done every day with a barn floor scraper snow shovel and leaf blower.
Maybe overkill, but makes the work area prettier and safer.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
red
Blowing is the way to go .... even a landscaper push type can run for a minute and move a lot of sawdust and you don't need to hold it
MP_Wall
You might want to look at one of those roller brushes that the pavement companies use.
