Author Topic: drying wood in basement with Home Depot home dehumidifier?  (Read 1430 times)
Offline DPForumDog
« on: September 26, 2015, 11:53:06 PM »
We tried an experiment and are drying some pieces of red oak  (3x9x100)in our basement with a regular home dehumidifier.   We are having great success  (fast) according to the moisture meter.   What are the disadvantages of drying wood this way.
I had heard insects might be a problem, but so far I have seen no evidence of bugs.
All discussion appreciated.
Granny DP
DPForumDog
Granny DP
DP Forum Dog
Offline GeneWengert-WoodDoc
Re: drying wood in basement with Home Depot home dehumidifier?
« Reply #1 on: September 27, 2015, 07:57:01 AM »
The risk is that the huge amount of moisture could raise the basement humidity and cause corrosion, but with only a few pieces and a working DH, you are likely ok.  The moisture released is fairly acetic...with acetic acid, so some corrosion is possible anyway.
You already know about insects.
The final MC for interior uses is generally around 7.0% MC, which means the basement needs to be about 26% RH.  This can be hard to achieve with a DH in a basement in your climate.  In a basement, the RH with a DH might be closer to 40% RH, which means 9% MC is more likely.
Offline DPForumDog
« Reply #2 on: September 29, 2015, 12:08:59 PM »
So its not bad for the wood?  I was thinging it was going to fast.
Now I am scared of the insect issue.    I had my husband remove the wood and we bug bombed the basement.
Granny DP
DP Forum Dog
home depot 40:1
Started by havenodog on Chainsaws
Last post November 21, 2006, 10:50:36 PM
by sawguy21
Mexican Home Depot
Started by WV Sawmiller on Sawmills and Milling
Last post August 30, 2016, 01:25:33 PM
by venice
Home depot prices
Started by hookhill on Sawmills and Milling
Last post December 07, 2006, 12:33:07 AM
by Rockn H
Home Depot chainsaw sharpener
Started by albert001 on Chainsaws
Last post June 18, 2020, 03:26:24 PM
by Philbert
