Dynamic Green Products Inc.
Author Topic: Just picked this up  (Read 7329 times)
Offline woodsdog2015
  • Newbie Woodcutter
Just picked this up
« on: October 02, 2015, 01:34:48 PM »
I was driving home from work yesterday and saw this at a yard sale.  I didn't have a clue what it was but knew it was a big saw and it looked in decent shape except for the chain and very small bar.  What is this saw worth.  I wanted another back up saw and that was my interest but when I started to google this it appears there is some collector value for this.  I want to use it and it started up good after I put some fresh non-ethanol 91 at the recommended 32:1 ratio.  The previous owner said he bought it new and he used it last year but the rear sprocket housing/brake cover inside and out was covered with oily gunk.  I spent all evening cleaning it, taking apart the chain brake and giving it a good cleaning.  The manual came with it and it said not to take the clutch off have a dealer do that.... do any of you folks have experience with this saw and I would take recommendations on a compatible longer bar and chain for it?
I'd rather be in the woods.
MS362CM
MS251
CS-300
Homelite 8800
FiskarsX27
Offline sawguy21
Re: Just picked this up
« Reply #1 on: October 02, 2015, 07:48:34 PM »
First I have heard of this model, Mike Acres site has nothing on it either. It looks like a Solo, they built some Homey's in the 80's, but they weren't made in the U.S. and parts are non existent. If it has .325 chain the longest bar readily available would be 20".
Offline WV Mountaineer
« Reply #2 on: October 02, 2015, 07:54:03 PM »
That saw says "Made in the USA".  So, it isn't a solo.  God Bless
Trying to live for the Lord, spend all the time I got with family, friends, hunting, fishing, and just enjoying my blessings.
Offline Pine Ridge
  • Part-time logger, Full time loafer
« Reply #3 on: October 02, 2015, 09:54:55 PM »
My dad was a homelite fan, a 944 homelite was his pride and joy. I've never saw one like you've got, it looks like its in really good shape.
Husqvarna 550xp , 2- 372xp and a 288xp, Chevy 4x4 winch truck
Offline 67L36Driver
« Reply #4 on: October 02, 2015, 11:09:30 PM »
Solo is good bet.  88.5cc, big motha.  Homelite 540 is same as 880.
30" bar would be no problem for that puppy.
Over 40 old magnesium runners.  Plei Trapp Valley Duck!!! Club.
  • Newbie Woodcutter
« Reply #5 on: October 03, 2015, 06:20:44 AM »
Its not .325 the manual says "The 8800 is equipped with a 3/8" pitch drive sprocket, both 3/8" and .404 square ground chisel chains are available. Order drive sprocket part no. 63285-A to equip the saw with a .404 chain."  So my interpretation is that it'll use a 3/8" chain.  As far as bar length the longest listed is a 31" sprocket nose.  It has combos ranging from 20" up to the aforesaid 31"  from 70 links for the 20" bar up to 103 for the 31" bar.  I was thinking of outfitting it with a 24" bar I wonder if Oregon or someone else makes one that will fit this????  As far as this being a Solo, I don't even know who that is but the owners manual says "Homelite Division of Textron Inc." Headquarters in Charlotte, NC USA with Overseas offices in the Netherlands, France and Australia and Canadian Offices as well.  The manual was also printed in the USA so I think this is an American Made Homelite.
MS362CM
MS251
CS-300
Homelite 8800
FiskarsX27
Offline 49er
« Reply #6 on: October 03, 2015, 10:16:46 AM »
I found this with little trouble.
i Dennis,
Yes, the 8800 is virtually identical to the 540. Looking at the IPLs, the muffler appears to be slightly different, the 8800 has an air deflector on the carb inlet whereas the 540 doesn't, but in general everything else appears identical. There may have been changes to the porting, piston rings,carbs, etc. but I can't tell this from IPLs. Most part numbers are different due to nomenclature changes and I haven't cross referenced, but I'd dare say they're the same parts. I have also heard these were Solo saws, but I have no clue what the Solo equivalent was.
Based on some of my workshop manuals, the 410 was out a few years before the 540 and/or 8800 were inroduced. General design of the 410 and 540 are similar. Both have a handle/tank assembly thats isolated from the engine at 6 rubber anti-vibe locations. Similarities end however at the general design as few parts interchange between the 410 and 540. The 410 has a reed cage with the carb on the left side where the 540 was piston ported with the carb up top. They even use different fuel caps.
Husqvarna EC390 365xt
Jonsered 2188 2165 2260 2253 70e
Redmax GZ4000
Offline HolmenTree
« Reply #7 on: October 03, 2015, 11:31:42 AM »
From my information the 540 Homelite was introduced in 1987 and was still marketed in 1990.
I suspect the 8800 came out mid 1990's.
It's debatable that the 8800 is a rebadged Solo as the 1987 Homelite 540 is exact design right down to the same decals as the 8800 in the OP'S picture.
  • Newbie Woodcutter
« Reply #8 on: October 03, 2015, 01:51:10 PM »
Thanks for the information so if I couldn't find a part for the 8800 I could likely use 540 parts for the most part?  What bar and chain would you recommend?  I'm going to try this out as is after I clean it up some more, tension it and sharpen the chain but I'm thinking down the road a total bar and chain replacement and this saw should be good to go.
MS362CM
MS251
CS-300
Homelite 8800
FiskarsX27
Offline 346xp
« Reply #9 on: October 03, 2015, 02:01:43 PM »
The 540 and 8800 were beasts back in the day!! Good luck with it
Offline mcourtney
« Reply #10 on: October 07, 2015, 01:33:25 AM »
I was told a few years ago that Solo designed some saws for Homelite so they could have a commercial duty saw to compete with the pro European saws. I have actually ran one of these , quite the thumper.
Online Spike60
« Reply #11 on: October 07, 2015, 07:08:28 AM »
I believe the 540/8800 are genuine Made in the USA Homelites.
Only Homelite models that I'm sure were built by Solo were the 290 and 340. They were rebadged Solo 647 and 654 saws; 47 and 54 CC's.
I think that because this is the case with those saws, the "made by Solo" label occasionally gets pinned on a few genuine Homelites by mistake. Especially a few of the less common saws that Homelite introduced near the end, like the 540/8800. If they were made by Solo, there would also be Solo models on that chassis, and I'm not aware of any such saws. If Homelite had received any large saws from Solo back then, they would have been rebadged 680/690/603's.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
Offline HolmenTree
« Reply #12 on: October 07, 2015, 11:09:27 AM »
The Homelite 540/8800 is definitely a "made in U.S.A." engineered saw as my pictures prove here.  From what I can see it was the last good big displacement pro saw out of North America .
It was introduced with good timing as one year earlier in 1986 Stihl set the chainsaw industry on it's ear with the introduction of the 85cc 064AV.
The Homelite 540 had a good manufacturing  run up into the early 1990s and had to be a good design going that many years since 1987.
By 1990 the 540 dropped a 1/2 lb. drop in weight and added 3 oz extra fuel capacity. Specs in 1990 show the 88cc 540 weighed 16.0 lb. The Husqvarna 87 cc 288XP weighed 16.0 lbs.
Offline fossil
« Reply #13 on: October 07, 2015, 11:57:24 AM »
You can find an IPL for the 8800's about half way down the page at this site.
http://www.mymowerparts.com/pdf/Homelite-Parts-Manuals-For-Chain-Saws/
Tim
  • Newbie Woodcutter
« Reply #14 on: October 07, 2015, 12:14:56 PM »
Great info. folks thank you this is very helpful.  So would any 3/8" pitch chain work on this saw then?  The rails on the bar are worn over so I'm going to file those down too.... what about an aftermarket bar for this?  Does anybody have a resource?  Thanks again for the interesting information.  I want to get cutting with this thing!!!
MS362CM
MS251
CS-300
Homelite 8800
FiskarsX27
Online Spike60
« Reply #15 on: October 07, 2015, 12:56:37 PM »
Oregon still makes bars for these Homelites. Sizes are limited to 20 and 24 Inch lengths. 24" should balance out real nice on that 8800.
Husqvarna-Jonsered
845-657-6395
Offline sawguy21
« Reply #16 on: October 07, 2015, 01:48:41 PM »
I suggest going to the Oregon site to match your bar's tail pattern.
  • Newbie Woodcutter
« Reply #17 on: October 07, 2015, 03:59:41 PM »
Excellent!  Thanks!
MS362CM
MS251
CS-300
Homelite 8800
FiskarsX27
  • Newbie Woodcutter
« Reply #18 on: October 07, 2015, 04:25:45 PM »
I went on the Oregon Bar & Chain Selector site and they don't have the 8800 listed but they do have the 540 listed.  Since this is virtually the same saw, should I just use that to select the right bar and chain?
MS362CM
MS251
CS-300
Homelite 8800
FiskarsX27
Offline rburg
« Reply #19 on: October 07, 2015, 06:40:35 PM »
yes
picked up a new saw
Started by Deere80 on Chainsaws
Last post October 05, 2016, 11:43:56 AM
by Jazzbery
Just picked up a TK B20.
Started by wewacountryboy on Sawmills and Milling
Last post October 19, 2014, 12:42:55 PM
by ARp
look what I picked up
Started by Nailhead on General Board
Last post January 25, 2006, 12:27:37 PM
by Nailhead
Picked up my new to me 440 B
Started by RayMO on Forestry and Logging
Last post December 09, 2014, 07:16:20 PM
by KyLogger
