My Hydraulics
Started by POSTON WIDEHEAD, November 25, 2015, 05:36:04 PM
POSTON WIDEHEAD
Had just finished the last edging on a Cedar Job this afternoon.
BAM....HD went stone cold dead.
Called WM and together we went through the trouble shoot.
Conclusion, the solenoid went bad and possibly the micro switch. They are shipping me new parts now and will be here Monday. Simple fix.
My question.....what causes a solenoid to go bad?  say_what
Thanks Woodmizer!
snowshoveler
In my world of lawn and garden equipment.
A solenoid failure is almost always caused by a low voltage condition.
Check grounds first and go to battery and alternator next.
Regards Chris
International T5 dozer
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
bkaimwood
Typically, solenoids fail due to their own design, in other words failed contacts, or open windings....but I think I know what your thinking...what is the root cause of the problem,  the one that caused the solenoid failure? In most solenoid failures, there is none...I wouldn't sweat it for now...
bk
Nomad
     Which solenoid?  They do give it up.  Last one I had go out had a wire break internally and it worked when it felt like it.  Gave me fits for a couple of weeks before I finally found it.  These are not the most robust solenoids on the planet.
     It is possible it's the switch, but that would be easy to troubleshoot.  just jumper around it.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Kbeitz
Most of the time a solenoid quits because the copper bar wears down so it does not touch the two lugs anymore.
Love machine shop work
and Wood work shop work
And now a saw mill work
kenlt30
The diode on my hydraulics solenoid went bad, allowed current to flow both ways. Disconnecting the diode is a temporary fix after replacing the switch. Shorted diode fries the switch.
Kbeitz
Diodes are cheap... Put one like this on it and you wont need to do it again...
The diode shown above does not apply to the solenoid in question.
David, be sure that your contact strip is clean and shiny and the contactor is moving freely against the spring and is not badly worn.  Also your ground contact on the bottom rail.  Without good contact in both locations means low voltage and high amperage which will put a real strain on both the solenoid and your hydraulic pump motor.  Since you had a hydraulic motor failure in the not too distant past, I would really look closely at both of these contactors.
POSTON WIDEHEAD
Quote from: Magicman on November 25, 2015, 07:55:19 PM
Good advice.  :)
POSTON WIDEHEAD
I am getting good voltage going to the solenoid. Then I crossed the 2 large connectors and the motor ran strong.
I will check everything from strip to ground. Even if thats not the problem, it will not be a bad idea to clean things while waiting on a part or 2.
Is there a Solenoid compatible at O'Riley's, Auto Zone or Advanced Auto?
YellowHammer
Quote from: POSTONLT40HD on November 25, 2015, 08:05:01 PM
Make sure you check the voltage drop across the main terminals while under load.  Also, check the trigger voltage before and under load.  Many times that is the culprit, causing a little chatter.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
POSTON WIDEHEAD
Quote from: YellowHammer on November 25, 2015, 08:39:56 PM
I'm learning. Thanks YH
WV Sawmiller
David,
   May be different issue than yours but I had intermittent hydraulics failure and had to keep moving the head till I found a live spot on the strip. Was a real PITA. I had sanded down burnt spots from arcing (Caused by me moving the head while working hydraulics before I knew better), sanded the bottom rail and coated everything in dielectric grease. None of these tips worked well. Called WM electrician and he was almost brusque in telling me to move the contactor over 1/16" of an inch closer to the strip. I did and it has worked perfectly ever since.
    Good luck.
Kbeitz
Why does a solenoid even need a diode ?
The solenoid has a small diode across the primary to prevent arcing and increase the life of the microswitch.
Kbeitz
Quote from: Magicman on November 25, 2015, 11:00:44 PM
Ok... Got it...
What you need is a  Zener diode.
danreed76
Must be something in the air... I went out to fire the lt-40 up yesterday and halfway through bringing the loading arms up it went quiet.  Got the meter out and found the solenoid wasn't closing.  I had one in the tool room, as I have slowly collected some of the "recommended spares".
Woodmizer LT40 Hydraulic with resaw attachment |  Kubota MX5200  | (late)1947 8N that I can't seem to let go.
Yup, I replaced a solenoid a couple of months ago.  A couple of spares are always in the truck.   ;D
Dave Shepard
If it's the solenoid near the battery box, you can move the left cable to the right lug to bypass the solenoid. Your hydraulics will be live whenever the head is on the strip, even if the key is off. If you lose the one (or two on Supers) in the hydraulic box, you could steal the one in the fuse box, and bolt the two cables together in place of the solenoid. Not ideal, but would get you through a job in an emergency.
Good point Dave for a get-by fix.
The older non-SuperHydraulic LT40's did not have that solenoid beside the fuse box and the hydraulics are hot any time that the head is on the contact strip.
Just curious, are the newer non-SyoerHydraulic LT40's equipped with this solenoid?
Dave Shepard
The '99 standard hydraulic at work has the solenoid in the fuse box by the battery.
OK, then it is probably a feature from then on.  WM made many upgrades in mid 1998 that carry through to today's version.
red
Sawyer has way to much Voltage. . .needs to be better Grounded.  . that's what I was told many times.. happy turkey day
slider
David i don't think you will find that solenoid at the local parts house.I did some research on line and found that wm was about the same price as others.
al glenn
POSTON WIDEHEAD
Quote from: slider on November 27, 2015, 08:33:38 AM
Thanks Al.  smiley_thumbsup
