Author Topic: Elk (venison) an Beans  (Read 928 times)
Offline pappy19
« on: January 08, 2016, 11:56:00 AM »
This is a take off of Burt's Beans-
Elk & Beans
-Take 6 slices Elk chopped approximately 1 1/2-2 pounds
-1 Large Onion chopped
-3-4 cloves of garlic, minced
-1 16oz. can of Pork & Beans
-1/2 pound thick cut Bacon
-1 16oz. can of Kidney Beans (drained)
-1 16oz. can of Butter Beans (drained)
-1 1/2 cup packed Brown Sugar
-1 cup Ketchup
-2 tablespoons Vinegar
-1 tablespoon Worcestershire Sauce
-1 teaspoon Salt
-1 teaspoon black pepper
-1 teaspoon prepared mustard
-1 cup Molasses
Heat oven to 350 degrees. In Dutch Oven, cook bacon over medium heat on cooktop, until crisp. Remove bacon and set aside. Drain all but 1-2 tablespoons bacon fat. Add meat, garlic and onion. Cook over medium heat, stirring occasionally, until meat is no longer pink and onions are tender. Add chopped bacon and remainder of ingredients to pot; stir well. Cover and bake in oven until bubbly around edges 45-60 minutes.
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Elk (venison) an Beans
« Reply #1 on: January 08, 2016, 12:20:02 PM »
Pappy,
    Looks good but I would think canned beans would cook to mush in the time shown. I'd have thought you'd be using dry beans (Kidney or Pinto) for something like that.
   Have you ever tried it using canned venison? I have some left I need to use up and might be a good use for it. I might have some tenderloin or roast left but most everything else we cubed or ground. I'm sure the tenderloin (actually loin as I have been reminded on other threads) should work well.
Offline pappy19
« Reply #2 on: January 08, 2016, 01:52:29 PM »
Both the kidney beans a butter beans hold up well and do not mush. Already cooked pinto beans will mush. Dutch oven pinto beans take about 3 hours here in Idaho altitude. If I was going to use dried pintos, I would cook them for a couple of hours with a ham hock, salt and bay leaf, then add the rest of the ingredients and cook for another hour until the beans were done. This is just a good quick recipe that doesn't take a lot of work for a great dish.
Pap
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
Offline drobertson
« Reply #3 on: January 09, 2016, 07:17:47 AM »
one thing for sure there Pappy, some of you folks sure eat well up there!
Offline Carson-saws
« Reply #4 on: June 24, 2016, 04:22:34 PM »
Sounds absolutely fantastic!!
Let the Forest be salvation long before it needs to be
Where's Da Venison
Started by chet on General Board
Last post December 08, 2003, 05:14:57 PM
by EZ
New to me venison recipe
Started by Trax on FOOD! FOOD! FOOD!
Last post April 19, 2010, 01:21:21 AM
by Samuel
Venison on the rocks
Started by mike_belben on FOOD! FOOD! FOOD!
Last post February 14, 2019, 12:16:16 PM
by mike_belben
Venison pepperoni
Started by petefrom bearswamp on FOOD! FOOD! FOOD!
Last post December 30, 2014, 06:16:17 AM
by Al_Smith
