Modifying log dogs?
Started by Satamax, March 08, 2016, 04:51:11 PM
Satamax
Hi everybody!
I have bought this saw last year, without log dogs.
Last saturday, i've bought three log dogs from a vertical sawmill. Without motors.
They are too long. The screw is floating in there. so the top dog would screw down until it touches the wood, and then the screw drags the bottom dog back up, until it gets tight. So the screw sticking out at the side, if used horizontaly, would interfere with the saw's pilars.
What should i do, fix the "bottom" dog, cut the screw and it's tubular protection at the end? To make this fit on the saw? Or i go another way, stuff a pneumatic ram in there and ditch the screw completely?
Thanks a lot for your opinions and advice guys.
Satamax
Another thought,
I'm not too keen on using hydraulics, as the tubing costs an arm and a leg too.  Tho, I have two rams which could do the job. And in the mountains where I live, hydraulic power units are quite common. And rams are cheap too.
ozarkgem
That is one heavy duty looking set up. How many horse power is the motor? It looks a little small for everything else being so massive. No help on the dogging system. What kind of trees are you sawing?
Satamax
Hi Orzakgem.
The motor is 22KW 415Vac Not the toughest, but with stellite bands, it should work all right. I could get a 40kw may be. But would the future generator cope with any bigger than 22kw, dunno.
It will saw mostly euro larch. Arolla pine, Pinus uncinata and the likes. May be a little wild cherry, ash, beech. Lime and silverbirch may be. Nothing much else worth cutting grows here. Sometimes we can get some spruce too.
Hth.
Max.
Satamax
Question readers; does the log dogs on horizontal saws float  a bit to adjust to the possible unevenness in the log? Or one of the two claws is always fixed at a certain spot? Because if I go for one fixed end, it makes my life far easier.
Thanks a lot.
Max.
ozarkgem
can we get some more pics of the mill? the backside, feed system , head movement and such. Does it have hydraulics now? Is it a factory rig?  thanks
Satamax
Quote from: ozarkgem on March 09, 2016, 08:55:52 PM
It's a factory rig.
From LBL Brenta nowadays. Started out as another company, called scies CD.
Here's their actual leaflet: http://www.lbl-brenta-cd.com/doc/19_cd-bandsaw.pdf
Here's a vid of a later one in action. https://www.youtube.com/watch?v=d6tjDJ14GCY
This is a pic of the back.
The head movement is manual rack and pinion on the back columns; And the head movement is an auxiliary electric motor, with chains on all four rollers.
HTH.
Max.
ozarkgem
its a beast for sure. I would go with hydraulic motors for the dogs. You will still have to have some back stops for turning the logs. Looks like some bed cross members also. Beautiful country you are in.
Ron Wenrich
I've always been partial to hydraulic.  One advantage is the ability to feather your controls.  If you're planning on adding the chain style log turners, the hydraulics will come in handy.   You could fix the bottom dog, if it works for you.  On a vertical mill, the bottom dog floats a bit, but it doesn't move that much.  About 6".  You aren't cutting in that plane, so you don't have to put that much taper in it.  You should have a taper adjustment someplace to help center your heart.  A hydraulic ram could take care of that.  The air tapers I've run have either been on or off, where the hydraulic ones you can adjust better.
Satamax
Thanks a lot guys for your replies.
orzakgem, I doubt I will go hydraulic for the motors. Too much hassle.
Tho, Ron, I will take your advice about using hydraulics for the taper.
For the dogs, I will shorten the rail of about 4 inch. At what is the bottom for the moment.
Then I will not fix the movement of the "bottom dog" but rather limit it, and adjust the length of the screw accordingly so it wouldn't go out of the  protection tube. Now, it's matter of finding the right motors and pinions.
Then, for rotating the log turning. I was thinking about car hubs, from a 4x4, with "toothed" discs. Powered by a three phase moto reductor. And a ram for lifting those out of the rails.
Whatdayathink?
kelLOGg
Out of my league, but I sure do like that vacuum lumber lift!
Bob
Ljohnsaw
Quote from: Satamax on March 09, 2016, 07:28:54 AM
Hi Orzakgem.
Hth.
Max.
Maybe someone can translate for me.  I always thought 746w (.746kw) was one horse power.  So that means that 22kw would be about 28hp?  That can't be right.  I, too, like the vacuum lift!  That video was nice but seems like it cuts pretty slow - maybe hardwood?
Max, just for scale, what is the distance between your rails?
John Sawicky
Satamax
John, 736w for a HP, so that's 29.89hp. Tho, that's three phase 415v, not petrol HP. Which seem overrated all the time.
I have aproximately 160cm between rails. About 5.25ft. They're not fast machines in that HP range. But i have seen some fitted with up to 60kw motors. I actualy could do it, as i have one 67kw, wound rotor.
Mind you, i don't have the gen set to power it. This motor is meant to be turned into a generator.
Ljohnsaw
Well, I guess I had it right.  But that is a BIG electric motor!  Good luck with your project - will be following along. :)
John Sawicky
Kbeitz
High/ low voltage ... Ac/DC.... All make a difference...
Amps calculation with voltage of 12V DC
For DC power supply, amps are equal to watts divided by volts.
amp = watt / volt
amps = 1000W / 12V = 83.333A
Amps calculation with voltage of 120V AC
For AC power supply, amps are equal to watts divided by power factor times volts.
amps = watts / (PF × volts)
For resistive load without inductors or capacitors, the power factor is equal to 1:
amps = 1000W / (1 × 120V) = 8.333A
For inductive load (like induction motor), the power factor can be approximately equal to 0.8:
amps = 1000W / (0.8 × 120V) = 10.417A
Amps calculation with voltage of 230V AC
amps = 1000W / (1 × 230V) = 4.348A
amps = 1000W / (0.8 × 230V) = 5.435A
Love machine shop work
and Wood work shop work
And now a saw mill work
ozarkgem
Quote from: Kbeitz on March 10, 2016, 04:54:07 PM
amp = watt / volt
HUH   :D
Satamax
Kbeitz, you didn't like my dissing of petrol motors?  ;D
Well, all joking aside. No wories, i know ohms law.
There's one thing you have forgoten with lower voltages motors, line losses ;D
Anyway. Any advice about my dogs? They're uggly hey!
Kbeitz
Quote from: Satamax on March 11, 2016, 01:47:03 AM
Yea I just posted that to look at. I had it hanging at Grizzly when I was rewinding motors
to remind me not all motors are created equal.
