Building my Retirement Home or "My First 5 Year Plan"
Started by Weekend_Sawyer, March 23, 2016, 08:43:11 AM
Weekend_Sawyer
My buddy Dave is practicing with his drone. Most of his videos end in a crash, it's kind of his signature ending. He's an IT guy and started a Youtube channel for me called Harzer Built. Here's a flyover that doesn't end in a crash but almost.
July 26, 2020 - YouTube
Imagine, Me a Tree Farmer.
samandothers
Roxie
Say when
GRANITEstateMP
Jon anymore updates? You been able to keep the critters at bay?
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
Weekend_Sawyer
Progress!! It's a wonderful thing.
The garage doors are up.
I just couldn't find hinges heavy enough to hold a 275lb door so I have been fabricating them. First I didn't get all of them done in time. I needed 16, 4 for each door. So we stood them up and tacked them in place. Then it turns out my welds were bad. I was using a wirefeed and had the polarity reversed so I just wasn't getting penetration. My welds were barely stuck to the surface. I figured out my problem, thank you youtube, and will be taking the last of them up this weekend. They are 19" overall.
Meanwhile, the stairs from the basement are in. They put on temporary treads because I want to make some nice
1 3/4" thick red oak treads to be installed after the heavy construction is done.
and they are working on the stairs up to the loft.
They will start basically where that pile of lumber is in the lower left, run up to a landing then turn and run to the right up to another landing that goes into the loft.
It kills me not to be there while so much great work is going on.
I'll be retiring at the end of October but were going to shut down for hunting season by then. These guys take their hunting seasons serious.
I still don't have a layout for my main level but I'm not worried. It is slowly evolving. I know where a couple of doors are going but I'm just not settled on the whole kitchen, living room, bedroom layout. So pretty much the whole thing is still a blank slate.
Jon
Tom King
Looks great!  I like your hinges.   Richards-Wilcox makes some that would work, but when you saw the price, you would probably have fabricated them anyway.
They even make huge stainless steel, ball bearing ones for Zoo's.
GRANITEstateMP
Thanks Jon, really enjoy watching this build! A new house, AND, retirement  8)! That's a win-win
Hakki Pilke 1x37
Kubota M6040
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
moosehunter
Nice hinges! Do you have more pics of the building process for them?
mh
Higher than my expectations
Weekend_Sawyer
Quote from: moosehunter on August 24, 2020, 08:46:47 PM
mh
I'm sorry I don't. I had planned on doing a Diresta style video but just ran out of time.
Here's how I made them.
 If you can weld a little they are not hard. I used 3/16 flat iron for the wings. The wings that go on the doors are 3" wide with a 2" wide piece on top, 14" long. The wing that gets screwed to the frame is 6hx5w" giving me lots of area to screw into the oak post. I should have staggered the holes. I bought most of the metal from a metal supplier near me. The knuckles are a 3/8 rod for the pin with a metal tube that they fit in. I bought this from a big box store, the rod and tubes were right next to each other. I cut the rod slightly over 6" then cut the tube into 2, 1.5" pieces and 1, 3"piece.
Assembly:
 on the pin I slide a 1.5" tube then the 3" then another 1.5" and peen the ends of the pin a little to keep it all together. Using magnets I line them up on the edge of the 6" side of the wing and weld the 2, 1.5" tubes to it. Then I line up the 3" wing and weld it to the 3" tube. I grind this weld back a little bit and then lay the 2" wing on top of the 3" wing and weld it down. All along making sure everything is plumb and square.
 My welding isn't very pretty but I can make stuff stick together... usually.
Jon
gspren
I believe that's called a "Gorilla Weld", strong but ugly!
trimguy
I just read this whole thread. WOW !! Very exciting. Thanks for posting. I'm looking for more updates when I come.
Weekend_Sawyer
All of the hinges are in and holding!
I finished insulating the garage doors. One thing about cutting insulation board is that there was pink residue everywhere. I bet I'll be finding it for years to come.
Here's a link to a video walk through showing where we are now.
Lodge progress. - YouTube
I'm hoping we will get the chimneys done so I can put a wood stove in the basement this fall. They are going to be exposed double wall stainless steel pipes. I like the way they look.
Jon
samandothers
Thanks for the tour!  I got a little winded coming out of basement!  Great looking place, y'all have done some great work!
doc henderson
that looks great.  glad you did not poke you feet between the joists.
scsmith42
Tom's 3638D Baker band mill
That will be an awesome place Jon, thanks for the walk through.  8)
fishfighter
Thanks for sharing. Some fine work going on. Love the set up. ;D
Weekend_Sawyer
Things are slowing down as bow season is in and my contractor and buddy Wayne is an avid hunter. we have been working on small but important details like boxing in around the garage doors and insulating the basement windows. I'm hoping to have the chimneys up in a couple of weeks.
I pulled an old wood stove out of my basement, scratched it down and put a couple of coats of high temp black on it. I'll be taking it up to the lodge this weekend.
Jon
moosehunter
Slo progress is still progress.
Remember to have a good hot fire in that stove before you put it in the house. I was 15 or 16 when I thought it was a great idea to paint my dad's wood stove one summer. He forgot about the fresh paint come fall. That was a mighty chilly evening with all the windows open and fans blowing @ 40°!!!!
mh
Weekend_Sawyer
 I wasn't going to do a pre-burn in the stove but you are the 2nd person to say that. I'm slow but I ain't that slow. Wilco!
Jon
doc henderson
Weekend_Sawyer
We got the conduits buried.
I'm going to bury the power and phone from a pole to the south of my lodge to a new pole, not yet installed over by where the backhoe is. you can see the guywire in the middle of the picture, that and the pole right in front of my lodge will go away. Then a spur will come back from the new pole with transformer on it to the lodge.
It was a hard working 3 days.
Raider Bill
The First 72 years of childhood is always the hardest.
My advice on aging gracefully... ride fast bikes and date faster women, drink good tequila, practice your draw daily, be honest and fair in your dealings, but suffer not fools. Eat a hearty breakfast, and remember, ALL politicians are crooks.
