Yeah spreading is usually the issue, which is why you see tension rods in most done here (US) commercially. The tension rod often defeats the purpose of wanting the clear open space as it's not truly open. Buttresses can be costly and would not be typical here. First ask yourself, why do you want hammerbeam? Looks in a house? Will tension rods be a problem? Most engineers are going to want the tension rods to make sure it won't spread.I figure if it's a smaller frame, you might get away with no tension rod if you do a few things to direct the force downwards and reinforce to reduce spreading effects. With a larger frame, you're taking chances.When I first got into timber framing, I was really impressed by hammerbeam bents, but learning about the forces you are dealing with, makes you reconsider whether the headaches or potential ones are worth the extra work and risks. If you want a hammer beam bent to impress people, you can accomplish the same effect with a variation of queen or king post bent with organic timbers (natural and sawn on two sides, or full natural). With organic timbers, no two will be alike.
Wondering how long a ridge beam would be practical, or purlins, that would eliminate any risk of spreading.Not sure what length of building you are looking for but I would think that the bents could be far enough apart to get a clear opening over your evaporator.
There are many a sugar house out there with tie beam over the evaporator. The steam won't effect the timber.Jim Rogers
I would think that then you're going to have to design for the future evaporator, and work around your design for the current one.You can span long distances but you're going to need to have your design reviewed by a qualified timber frame engineer.Are you going to cut the frame yourself or are you going to hire it out to a timber frame shop/company?What is the longest timber you can mill? Or what is the longest timber you would care to buy?A hammer beam can work, you just need to make the posts large enough for the support. Again, proper engineer review and design.What is the snow load for your area?Jim Rogers
That's nice having the sheds to either side. I did one once like that with wings to either side, it makes a big difference. Farmer Jim, I don't think that what you are proposing is at all unreasonable @20' span with a 12/12 pitch. If executed properly you should have no issue. You could use the hardwood for your posts, hammers, and braces and use the EWP for rafters, purlins etc. That will help keep your dead load down. You are also smart to keep your outer bents non-hammerbeam. That is going to help with spreading, wind load, and overall rigidity. I'm assuming there is no basement to this so you will want to make sure your post to concrete connection is well thought out. You'll be putting a lot of strain there. What is your finished roofing going to be? If it's steel, snow accumulation is going to be nearly nil. Good luck with it. I'll bet it would make the coolest sugar shack around!
Started by Nate Surveyor on General Woodworking
Started by Don P on Timber Framing/Log construction
Started by mart on Sawmills and Milling
Started by postville on Forestry and Logging
