OldJarheads Milling Thread...
Started by OlJarhead, April 06, 2016, 02:06:53 PM
Bandmill Bandit
I did a description of the install process for the B56 some where on the forum but not sure where. The first time was a PITA,  BUT I learned a lot on how to get it done. First time took about an hour, a lot of cussing and scraped knuckles and the second time took about 10 minutes no cussing and no busted knuckles.
I always flip the idles side belt side to side when I change blades and at this point have changed the 2 belts at the same time.
I'll go find that belt change description and post the link. Next time I change belts I will do a video tutorial but that is about 250 milling hours or so away.
heres that link
https://forestryforum.com/board/index.php/topic,89693.msg1380237.html#msg1380237
Deese
I've got 19" band wheels and just put new carquest B56 belts on Saturday. Oh. My. Goodness. It took 2 pair of vise grips, a hammer, and a really stout flat head screwdriver. I've done it a few times and dread it each time. So frustrating!
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Deese
Thanks for reposting that link Banmill B. Very interesting.
Cooks AE4P Edger
paul case
Timberking did have a video on youtube about changing the b56 belts.
Spray lube, like WD-40 will help.
PC
pc
MartyParsons
Hello,
   I see very few B-56 belts in the field. Not seen many issues with the B-57 . Not sure why you would want to run the 56? Your call.
I have seen the B-57 stick in the wheel and cause the band to jump off. I usually check the belt at the beginning of the day if it is sticking remove the band blade and spray some WD40 or just about any lube in the pulley grove. I would not think anything liquid would stay on it long due to heat and centrifugal force.
I see a few wheels with build up between the belt and the wheel on service.
When we do an alignment during service we always replace the B-57 belt. The height of the belt will change as the belt wears and thus if a new belt was not used the deflection would be less when a new belt was installed.
Hope this helps.
Marty
Bandmill Bandit
Hey Marty
Thanks for the input. The main reason I use the B56 is because jack pine and white spruce seem to have a stickier saw dust and it make lumps under the drive belt side that are a continual PITA.  Since I have gone to the B56 on the drive side there are so many issues that just don't exist for me any more. i doubt every body will need to use them but they sure do make my milling life a lot nicer AND I don't have near as many broken blades any more. I now sharpen about 80% of my blades to the point of can't sharpen any more and they still are not broken when I toss em in the scrap bin at the welding shop in town.
in
Brucer
Sawing mainly Douglas-Fir, the only times I've had any build-up under the belt is when I've been sawing in a heavy snowfall (which I really try to avoid :(). Something about the combination of snow and sawdust seems to cause it to accumulate in the balancing holes in the bandwheel on the drive side. As soon as it fills the hole, the sawdust is attracted to the same spot and starts to make a bump at the bottom of the wheel.
If you run your mill with one or more of these bumps under the b57 belt, it will cause your belt tension to fluctuate up and down very rapidly. This is hard on everything in the drive train -- blades, bearings, drive belts.
You'll get exactly the same effect if you buy a cheap belt that has a raised area on the back of the belt at the splice. That's why I stick to Wood-Mizer branded belts.
In most situations the b57 is a self-cleaning belt. In a few cases a b56 will do a better job of keeping the sawdust out in the first places.
Bruce    LT40HDG28 bandsaw
B57's on both bandwheels serve me well so I see no reason to experiment.
Jim_Rogers
Quote from: Magicman on August 24, 2016, 10:38:49 PM
x2
John S
2018 LT40HDG38 Wide
OlJarhead
Belts arrived so I'll do some maintenance today and get the mill and truck ready for the next couple of jobs.  I need to return to the last job and finish it since I had no belts to replace the tore up one with and pulled off the job.  That will hurt a little since it's about 100 miles from me.  Then I have another job to do, a short one.  It's a Tulip a customer wants milled up.
She tells me she has enough logs to keep me busy for a half day...interesting that they pulled off the bark off.
tnaz
Quote from: Magicman on August 28, 2016, 02:29:50 PM
Oh what nice "logs".   :o
I hope my computer works when I get the tea out of it!! :D :D
Slingshot
   I would say the bark just fell off those nice logs.
_______________________________-
OlJarhead
LOL but for $85/hr plus setup etc and I'll be happy to mill them into whatever I can for the customer.
I am hoping, however, that they have some that aren't badly checked etc.
tnaz
I hear ya. :D
Carson-saws
that's the bottom line right there...
Let the Forest be salvation long before it needs to be
OlJarhead
Yup I'll saw that!
Used MM's chain trick to get the 'log' on the deck and started whittling it down :)
Took some chainsaw work to whittle down the outer edges a few times as this thing was just a tad too wide!  But I got it done :)
Moved on to the second 'big' wood and got it down then milled several small 'logs' until the last big chunk was chained onto the deck...got it milled square but ran into a nail.  Changed band, rotated the log 180 and milled it down.
Put some slabs/flitches up on the deck to square them up for lathe wood and hit more nails....called it a day but it was a good day $$$ wise and a day of sawing is a good day anyway :D
tnaz
Need more pictures!!! :D  That one looks interesting.
Glad you made some $$$.
OlJarhead
Sorry that was all I got this time
Czech_Made
OlJarhead
NOTE to self:  NEVER EVER EVER loan your end sealer to a customer AGAIN!!!  :snowball: >:(
I went to pick up my sealer and put the 5 gal bucket in the back of my truck....got home and thought "gee that looks awfully thick and chunky"...went to shake the bucket and the lid came out and a bunch of sealer spilled onto the driveway!  CUSSING and swearing I began to clean it up.
This is the second time someone did not put the lid on right and it came off making a mess....worst still they seem to fail to understand what the *DanG spout is for!  GRRRRR
Off to Chelan to mill up a dozen logs or so tomorrow :D  I am not at my goal for the year so everything else is golden :D
4x4American
Boy, back in my day..
GAB
Quote from: OlJarhead on September 17, 2016, 07:51:12 PM
An approx. 2 pound container of peanuts or mixed nuts has a roughly 4" opening.
I pour some anchorseal in one of those and give it to a perspective customer and they can end seal their own logs without contaminating my pail.
Gerald
ncsawyer
OlJarhead,
I noticed one of your outriggers in the picture was missing the plastic cap.  That's a pretty common thing for my LT40.  I couldn't ever keep them on.  I finally took each one out and run a bead of black silicon around them and put them back it.  Seems to work pretty good.  Keeping those caps on will keep the sawdust and bark out of your outriggers.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
