Walnut good news and bad news
Started by Brad_bb, April 17, 2016, 02:32:12 PM
Brad_bb
Good news.  I bought a walnut log 22" on small end x 11'.  this morning.
Bad news.... I have some work to do before I try to mill it.  That's fiberglass clothes line sticking out.
But the other good news is that it is sticking out and you know to remove the fixtureshangers before sawing.  That is a beauty of a log.   ;D
Ljohnsaw
Nice log!
If you don't mind me asking and you don't mind saying... What do you pay for a log like that?  And is there a discount because of the likelihood of some metal in there?
Can't wait to see what's inside.
Sixacresand
Quote from: ljohnsaw on April 17, 2016, 04:59:07 PM
Nice log!
According to my Norwood App for Smart phone it is about 200 BF and about 1650 Lbs.
Chuck White
Quote from: Magicman on April 17, 2016, 03:52:22 PM
Also applies to POSTED signs!
I like when customers leave them in place, then I slab heavy on that side of the log, thinking there might be a second set of nails a little deeper.
dboyt
Fiberglass won't be much problem, but hope you don't hit the nail that was holding it in place.  Do you have or can you borrow a metal detector?  It can make for some interesting grain patterns.  Nice log!
Norwood MX34 Pro portable sawmill, 8N Ford, Lewis Winch
Brad_bb
I use the Lumber Wizard 4.  My 3rd one in 2 years just failed.  One failed in the actual metal detecting electronics.  Two failed by way of the piezoelectric speaker/tone maker.  I am going to take this 3rd one apart per Lumber wizard and see if dust is causing the issue.  It's basically an aluminum plate that is caused to vibrate by the circuit lumber Wizard told me.  I'll dig it out and pray there aren't a bunch of other nails in it.  Walnut is worth risking a couple bands.
I use the metal detector primarily for reclaimed wood.  Is there another metal detector that anyone prefers for logs?
AnthonyW
So knowing there is likely metal, how would you (the more experience sawyer) position the log? I think the only logical options would be either 12, 3, 6, or 9 o'clock.
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
Brad_bb
I've only been milling for 2 years.  I have removed a lot of metal from reclaimed timbers that I milled so I do have experience from that.  If there are any other nails, I would suspect the same face as the clothesline hanger.  So after I dig that metal out, I'd put it face down (6 o'clock) and mill the back face first.  Then the two sides.  Last the face where i dig the hardware out.  I figure that way I some cuts on the blade before I destroy it.   ;D  That orientation might change if there were branches/crotches in the log, but there are not.
Started peeling the log this evening.  Will finish in the morning and post a pic.
Ron Wenrich
I've always put my defect on a corner.  That would include metal, and tried to saw around it.  The reason is that you can get a wider board and put your waste in the edging strips.  The nail or eye hook holding that piece of wash line will likely stain the wood.  Putting it at 6:00 instead of 4:30 or 1:30 will put your defect right in the middle of the board.  That doesn't mean that you shouldn't scan your log with a metal detector.
One thing I have often found with logs with trash metal, if someone has put metal at one place in a tree, they'll often put more somewhere else.
scully
This is a perfect example of yard tree syndrome . As sawyers we know the chances we take with this stuff . I don't mind trying to get what I can out of it but last time it was 1/2" rebar  3X .
I bleed orange  .
Brad_bb
Yes there may be other stuff in it.  I guess the orientation will depend on how deep I have to go for the clothesline hardware.  My goal would be to get a 10x10 boxed heart timber out of the middle and 4x8 brace stock on the sides of that, and boards from whatever is left.  This list is in reverse order of course.  I'd lay out and start with the outside boards and work my way to the timber.  I'm thinking if it got too raunchy with metal and wasn't working out, I could split the log with wedges and get what I can get.  So you wouldn't even attempt it scully?  This will actually be my first "yard tree" and I wouldn't do it if it wasn't walnut....oh heck, sure I would.  You gotta learn your limitations somehow.  ;D
Brad_bb
Peeled it:
I was hoping to see some of the metal but looks like it's deeper than I hoped.
Not ready to cut it yet.  We'll keep it in the barn til I'm ready.
LAZERDAN
ozarkgem
wish my barn was big enough to store logs in.
scully
Oh don't get me wrong I would saw that Dude into toothpicks ! I'll saw em all . I just don't freak out about it much ,Just because the big boys wont saw something like that ,don't mean it aint worth it !
I bleed orange  .
killamplanes
I'm jealous of your shed space I've got every inch of mine packed with priceless items I never use. My advise is tear into that log like it was any other it will tell u how u need to make ur cuts. and be flexible u might have to alter your deminsions.
jd440 skidder, western star w/grapple,tk B-20 hyd, electric, stihl660,and 2X661. and other support Equipment, pallet manufacturing line
Sixacresand
When you peeled it, was the bark already loose or did you have debarker?  BTW, nice shop/building.
Percy
Ive never cut walnut so my experience is questionable, but...Im gonna guess there is no metal in there and just the fiber/string/whatever. My reasoning is whenever I get a cedar or spruce with metal in it and a line/whatever leading to the surface of the log, its always bleeding or has a boil or a more serious defect than what Im seeing on your log.... Just my sunshiney opinion....dont send me a bill for your blade if it hits steel  ;D
Napowan
I have been in the exact situation. ...
There's never nothing to do.
Percy
Quote from: Napowan on April 22, 2016, 01:21:34 PM
Nice!!! Awesome wood. Looks like walnut hides the tramp metal well....I may have to rethink my guess....
