Tally-I/O
Author Topic: Lt35hd debarker hits bed rail  (Read 950 times)
Offline Toeboard
« on: April 24, 2016, 11:59:20 PM »
Hello lt35 owners, I just purchased an new lt35hd while making my last cut 1 inch from the deck I noticed the debarker guard was hitting the bed rail, I stopped the blade backed out of the cut and removed the board to investigate.
  What I found is the debarker guard is about 3/16 lower than the bed rails this is with the debarker moved out, with it moved in it is 1/8 low. I have adjusted the debarker up so it clears the rail at 1/8" this is with the blade at 1". Now my problem is the debarker blade is high to the bandsaw blade. The debarker blade shaft has a thinner washer on top the blade and a large thick washer on the bottom I am going to see if swapping them will get me on target.
 I really like the mill the training at woodmizer was great, I was wondering if any other lt35 owners have trouble cutting 1" boards.
Lt35hd BX25D tractor
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
Re: Lt35hd debarker hits bed rail
« Reply #1 on: April 25, 2016, 06:40:54 AM »
Hello,
  check the blade arbor on the motor. Make sure it has not slipped and moved down the motor shaft. You should have no issues with the guard hitting the bed rail at 1" cut.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: April 25, 2016, 07:58:50 AM »
Welcome to the Forestry Forum, Toeboard.   8)
Offline petefrom bearswamp
  • 70-12 still feel pretty good and going to retire
« Reply #3 on: April 25, 2016, 08:11:13 AM »
Welcom aboard
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #4 on: April 25, 2016, 01:38:33 PM »
If it doesn't make sense better figure it out or it's not done with you yet.  :laugh: :laugh: :laugh:
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Toeboard
« Reply #5 on: April 25, 2016, 04:01:11 PM »
I checked out the debarker this morning it still skims the bedrails but not hard like before. While towing the mill home I hit a dip on I-5 where they ground the asphalt at 50 mph hopefully that didn't tweak the band housing to the debarker arm.
Thank you guys for the welcome and Marty the adapter was tight.
Also no more alarm on the debarker, they now have a strobe light.
Offline derhntr
  • Sawing lumber is addicting
« Reply #6 on: April 25, 2016, 04:14:38 PM »
My debarker got knocked out alignment from hitting and binding on a knot. Mine has 4 bolts attaching it to the backing plate and 2 bolts for angle adjustment. Not sure how much difference there is from the LT40 to the LT35 systems. I would check to see if the debarker blade is level to the saw blade.
2006 Woodmizer LT40HDG28 with command control (I hate walking in sawdust)
US Army National Guard (RET) SFC
Offline Toeboard
« Reply #7 on: April 26, 2016, 10:25:56 AM »
Found my problem, the debarker arm needs to be shimed up it sits 1/8 lower from the bandsaw head to the articulate joint.
Thanks guys derhntr pointed me in the right direction now back to cutting 1" stock.
Offline derhntr
« Reply #8 on: April 26, 2016, 10:30:01 AM »
Happy to help Toeboard, took me a little while to figure out why my band was cutting above the de-barker cut.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #9 on: April 26, 2016, 04:53:38 PM »
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Building a DIY Homemade debarker for my Woodmizer LT35HD
Started by MikeySP on Sawmills and Milling
Last post April 22, 2019, 04:01:06 PM
by MikeySP
LT 40 Hits a Big Old Nail Video.
Started by richhiway on Sawmills and Milling
Last post August 24, 2019, 09:21:29 AM
by richhiway
No hits, No Errors, No Boards Left On
Started by Sixacresand on General Board
Last post October 30, 2016, 01:41:17 PM
by David Freed
Saw dies as soon as it hits wood. Stihl AV 024
Started by Geospeedjr on Chainsaws
Last post October 29, 2014, 01:24:17 PM
by sablatnic
