Pine board treatment
Started by Hunter1000, May 09, 2016, 12:30:12 PM
Hunter1000
Hi Everyone,
Newbie with this awesome Woodmizer.  Made some nice pine boards for barn siding, 5/8" after they dried to <20%.  Question - if I treat with oil based stain/preservative, do I need to sticker them again?  I coated heavy with the oil, and stacked them high on each other and doused sides and ends again, then put under some metal roofing to keep rain off.
Is it OK to just leave it like that for a few weeks while I wait for structure of barn to be built or you all think will get mold and discolored?  Thanks much!
Den-Den
Less than 20% moisture should be low enough to prevent mold, not sure how the wet oil based stain might react to dead stacking.
Hunter1000
Thanks much for your thoughts Den!  Appreciate the reply.
Ox
I'll bet a dollar you'll be just fine.  Boards are dry enough, oil is oil.  Not much to go wrong in my opinion!
Hunter1000
Thanks Ox - for the reply.  Enjoy your profile pic message too.  Nice to see some kindred souls up north!
woodmills1
next time lean them up against the building to dry and don't do it in the rain.
