Heart pine
Started by Den-Den, May 18, 2016, 09:04:47 AM
Den-Den
I have turned heart pine (aka fat lighter pine) a couple of times before, the first time was horrible, the second was a little better. My neighbor asked me to make something from a piece of pine he had been storing for "30 years or more". It had a few radial checks but not too bad. Nearly all of the sapwood had rotted off; the remaining wood had so much resin that the shavings stuck to the soles of my shoes forming a layer almost an inch thick.  From my previous experience, I knew that normal sanding was impossible. Wet sanding with mineral spirits worked very well, sanding while turning slowly kept the mess to a minimum. Still not my favorite wood but I will turn it again.
Finished with one coat of tung oil and waxed with paste wax for a low luster. Diameter is just over 8 inches and 9-1/2 inches tall.
Beautiful.  smiley_thumbsup smiley_thumbsup
That should be a treasured piece, and it should last much longer than Egyptian pottery.  :o   :)
LaneC
  That is a very nice piece. That amazes me as to how you can do that. I am going to go ahead and ask, how do you hollow it out, or is it 2 pieces fitted together? That is very very nice.
Man makes plans and God smiles
Savannahdan
Beautiful work.  Thank you for sharing.  I really should get back to using my lathes more.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
mesquite buckeye
Me like.  ;D 8) 8) 8) 8) 8) :snowball:
Den-Den
Quote from: LaneC on May 18, 2016, 10:24:21 AM
It is a single piece hollowed to about 1/4" wall thickness with some extra weight in the bottom.  There is a learning curve to the hollowing but not as difficult as you seem to imagine.
21incher
That is beautiful.  I have never seeen a a piece turned with the grain running in that direction before.   Thanks for sharing.  :)
Den Socling
WOW that turned out to be beautiful!  8)
Texas Ranger
Work of art, DenDen!
sawmilllawyer
Excellent work!!! Love the grain pattern.
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
A good job to bring out the beauty in a piece of wood.
Lud
Nice turning.  But that orientation may bite you.  Bowls and vessels have thin walls and that means temp and humidity changes will keep moving the wood.  Knots change a lot over time in a bowl.  I avoid them mostly.
It does look neat tho!
