Carburetor trick--sharing the wealth
Started by azmtnman, June 03, 2016, 12:47:18 AM
azmtnman
   My 20hp Onan hasn't idled for a while. A buddy of mine that used to be a mechanic (one from the era that had to troubleshoot rather than plug them in) told me the idle jet was probably plugged up. He told me to take the air cleaner off, start it up and rev it while I covered the air intake with my hand a couple times and it would probably suck the clog out. WORKED LIKE A CHARM!  8) 8) 8) 5 minute fix versus taking carb off.
   I've worked on carbureted engines all my life (on my own stuff) and had never heard that trick. Thought I would pass it on.
1983 LT 30, 1990 Kubota L3750DT, 2006 Polaris 500 EFI, '03 Dodge D2500 Cummins powered 4X4 long-bed crew cab, 1961 Ford backhoe, Stihl MS250, MS311 and MS661--I cut trees for my boss who was a Jewish carpenter!
Chuck White
Glad to here that it worked for you, I had never heard of doing that.
Thanks for sharing!
kelLOGg
DanG! Mine hasn't idled for a long time, either. Know what I'll try.
Bob
sandsawmill14
carb mechanics are far and few between now around here at least :-\ if you can even find one that will try its 50 / 50 shot on whether it will be better or worse when you get is back :-\  i will have to keep that trick in mind and give it a try next tine one is giving me problems ;) thanks for sharing it with us  :)
Czech_Made
That explains it, thank you.  I had recently  trouble starting a tiller and the only way it would start was thumb over the carburetor intake, like 98% choke.
But after it started the issue went away on it's own - must been what you mention, the stronger vacuum cleaned the idle jet.
Kbeitz
The Onan idle jet is under the float on the bottom of the carb,
A small chunk of music wire pushed in the jet hole with the adjustment
screw out will also remove 99% of any dirt. A blast of air will also help.
Love machine shop work
and Wood work shop work
And now a saw mill work
Ox
This is a new one one me as well.  Makes perfect sense, though!  I've always done it the hard way and did a carb breakdown.
bkaimwood
bk
kelLOGg
DanG again. It didn't work for me. I tried it 4 or 5 times. Twice the engine died but still wouldn't suck out the clog - if there is one. :'(
Bob
xlogger
Bob my engine would not idle good till I switch to non ethanol gas. Lots better now.
kelLOGg
I switched to non-ethanol gas about 6 months ago but saw no improvement.
Bob
sandsawmill14
Quote from: kelLOGg on June 05, 2016, 08:00:23 AM
Bob
i cant tell any difference in the ethanol gas or pure gas either but i figure its because i burn so much my saw gas is never over 2 weeks old and the mill gas is bought daily ;D but i guess it might be worse if i was keeping it on hand for months  :)
Czech_Made
I buy nonethanol gas for all small engines and also for my antique motorcycle.
Funny, further you go from DC, more available the real gas is :)
sandsawmill14
i have to drive 15 miles to get non ethanol gas so i wont change unless it starts causing problems :-\ i dont question pure gas is better but the ethanol stuff is good enough the way i use it :)
Percy
Whenever I have carb issues and the above method doesnt work, I've had good results pouring some fuel injector cleaner into the gas. Like more than what the instructions say(6 oz in 1 gallon). Very quickly, my neglected lawnmower with ethanol gas from last year still in it, seems to smarten right up....
Kbeitz
Take out the low idle adjustment screw before giveing it a hand job.
That opens an air way to help suck the dirt in...
Czech_Made
Quote from: sandsawmill14 on June 05, 2016, 09:33:33 AM
My pure gas station is 25 miles, but I make the extra effort for small engines, since they are the most sensitive to bad gas.  But good gas can sit in jerry can for few month without problems.
Anyway, here is a handy page:
http://www.pure-gas.org/
azmtnman
Quote from: bkaimwood on June 04, 2016, 08:52:30 PM
Old timers call it a hand job...
:D :D :D That's what he told me to give it!! I was trying to envision......
crazy
What's a carburetor?  Just kidding.  I will try both methods.  I have several small engines that I need to get running.
Kbeitz
Mix a tad of two stroke oil with your gas and it will last a long time.
jcbrotz
LOL I have to drive 15 miles to get to a gas station. :D Sorry had to but I use non-ethanol in all small stuff and diesel in the rest.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
plowboyswr
Quote from: crazy on June 05, 2016, 07:01:44 PM
Welcome to the Forum! ;D
Just an ole farm boy takin one day at a time.
Steve
crazy
Quote from: plowboyswr on June 06, 2016, 06:39:21 PM
Thanks.  This is a great forum and I have been doing plenty of reading.
Chuck White
Welcome to the Forestry Forum, Crazy.
tnaz
Another Welcome to ya Crazy.
Terry
