Author Topic: Sprocket shot?  (Read 2272 times)
Offline psychotic1
  • Earth First   We'll log the other planets later
Sprocket shot?
« on: March 29, 2002, 09:37:22 PM »
Hi folks,
I've been busy bucking up small alders for the gun club woodshed, and tonight I ran into a problem I've never seen before.  I was bucking up some poles when I noticed my chain was too tight.  So I loosened it a little and went back to cutting.  two or three cuts later, the chain is so tight, I can't move it by hand.  Loosened it again,  same thing.  Loosened it once more, and the durn chain came off the bar :o
So.  Took saw apart, checked bar, sprocket, and chain.  Sprocket seemed a little worn, but nothing particularly new.  Put everything back together, tightened chain up.  tightened down the bar bolt, and moved the chain by hand.  Chain went around a few times, then tightened up till I couldn't move it.  Loosened it up, and it was hanging down below the bar.  Tightened it incrementally until correct, and withing a couple of turns around the bar by hand, the chain was locked up again.  I can't seem to find the right spot.  Either it's loose enough to fall off, or it's so tight I can't move it.  Any of you chainsaw guru's got any advice for me?  Please?
Ps.  skilsaw 1616.  Don't know how old, but I can't get parts anymore.  The stihl dealer looked like he wanted to call a psychiatrist, and the homelite/yamaha/everything else guy just laughed.
Bruce
Patience, hell.  I'm gonna kill something
Offline Frank_Pender
Re: Sprocket shot?
« Reply #1 on: March 30, 2002, 06:56:51 AM »
Sounds as though you will have a nice wall hanging with the 1616.  ;)  then i would check out a new Stihl in the same physical size and hed back for the Gun Clum cutting. 8) 8)
Re: Sprocket shot?
« Reply #2 on: March 30, 2002, 07:52:00 AM »
Is your bar bent?
Have you got gunk in the chain groove? (stops oiling)
Is the sprocket running true on the shaft?
Is the chain worn and not tracking on the sprocket? (bend side to side)  Might not be the right chain too.
Well, That about does it for my suggestions.  I've hit the bottom of the barrel.  :D
Offline Kevin
Re: Sprocket shot?
« Reply #3 on: March 30, 2002, 10:30:11 AM »
Sounds like the tensioner is broken or disabled .
Have a look where it seats in the bar.
Offline psychotic1
Re: Sprocket shot?
« Reply #4 on: March 30, 2002, 11:08:57 AM »
Eventually, this saw is gonna end up planted in a rock by the bar, but I can't afford to replace it just yet.  Maybe next month.
Thanks for the hints guys.  I'll check it out today.  After fiddling with it for about 30 minutes last night, I set it in the shop and went to have dinner.  I'll go and tear it apart this morning.
Bruce
Offline DanG
Re: Sprocket shot?
« Reply #5 on: March 30, 2002, 09:11:52 PM »
Kevin's got it. The tensioner has had it. My ol' Poo-lan 3400 usta do the same thing(bless it's pore ol' dead soul :'(). Things get worn so that the bar will wig-wag up and down, and the chain tension will vary wildly.
3/8 lo pro rim sprocket
Started by Caloren on Chainsaws
Last post June 22, 2015, 10:48:46 PM
by joe_indi
Rim Sprocket for MS 460
Started by Good Feller on Chainsaws
Last post July 28, 2008, 01:13:30 AM
by Southernlogger007
385 with 8 sprocket...
Started by Ever Green on Chainsaws
Last post March 26, 2006, 10:40:30 AM
by Rob
034 sprocket
Started by Cliniford on Chainsaws
Last post December 21, 2008, 08:19:09 PM
by Cliniford
