Author Topic: Woodmizer klin  (Read 1511 times)
Offline steve marek
Woodmizer klin
« on: July 07, 2016, 10:34:13 PM »
Does any one use woodmizer solar klin or there drying equipment does it work well
WM LT40HD Logrite ach 718 woodmaster timber framing tools 3000 ford tractor 359 395 husky chainsaw woodmizer e50 single blade edger woodmizer 260 moulder 2538 mahindra tractor kd 250 kiln
Offline scsmith42
    • Whispering Pines Farm
Re: Woodmizer klin
« Reply #1 on: July 10, 2016, 08:36:46 AM »
I have a Woodmizer version of a Nyle L200.  Works great!
Tom's 3638D Baker band mill
Offline OneWithWood
  • I am happy!
Re: Woodmizer klin
« Reply #2 on: July 10, 2016, 10:42:46 AM »
I have a WM4000, which is a Nyle 200 with a Honeywell controller.  Easy to use and does a great job.
Don't have any experience with solar kilns.
One With Wood
Offline steve marek
Re: Woodmizer klin
« Reply #3 on: July 10, 2016, 01:24:07 PM »
is there a big learning curve on them or are they user freindly
Online GeneWengert-WoodDoc
Re: Woodmizer klin
« Reply #4 on: July 10, 2016, 06:55:41 PM »
North Central Technical College in Antigo, which is just a few miles away, has a beginners' class every year in August.  You can learn everything you need to know in order to run a DH kiln efficiently and effectively.
In WI, the solar kiln is going to run well from April through September, but you might want dry lumber year round.
Offline Den Socling
  • just wondering
Re: Woodmizer klin
« Reply #5 on: July 10, 2016, 09:32:52 PM »
Steve, Gene is an expert  on the subject. Take his advice and attend the class.
Offline scsmith42
Re: Woodmizer klin
« Reply #6 on: July 12, 2016, 08:41:30 AM »
There is a serious learning curve to any kiln drying process, not just the WM unit.  Ditto's Gene's recommendation about attending class.
Offline steve marek
Re: Woodmizer klin
« Reply #7 on: July 13, 2016, 10:38:00 PM »
Do they have the class every year in August I like to attend this year I have prior commitments so I will not able to attend but would like to schedule it for next year if they are having the class
Offline Den Socling
  • just wondering
Re: Woodmizer klin
« Reply #8 on: July 13, 2016, 11:34:14 PM »
Kiln operator associations often overlap geographically and many hold training to some degree or other. Gene offers the best classes IMO. I used to keep track and post notification of meetings at the top of the page. I'll try to put a little time into that again.
Re: Woodmizer klin
« Reply #9 on: July 14, 2016, 08:16:36 AM »
The class in Antigo is every year in August.
Offline scsmith42
Re: Woodmizer klin
« Reply #10 on: July 14, 2016, 08:57:10 AM »
Steve, I would suggest that you attend a class before drying any significant quantities of lumber with a kiln.  There are many ways to damage lumber during the drying process, and a class will help you understand the basics.
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
Re: Woodmizer klin
« Reply #11 on: July 14, 2016, 12:00:31 PM »
Although most of the classes will have similar titles, and the basics principles of drying are there, classes are not all the same !!!!  I learned the hard way.
Make sure you verify that the class you are considering will be appropriate for the type of kiln you will be using/building/buying.  Driving over 1000 miles, and spending considerable money, to find that the instructor has a 'disdain' for your type of kiln is very frustrating.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
solar klin
Started by steve marek on Drying and Processing
Last post April 10, 2012, 10:00:47 PM
by treenail
Building a solar klin
Started by Moulder on Sawmills and Milling
Last post April 22, 2003, 07:55:19 AM
by Rick Schmalzried
20 feet container for Klin is it OK
Started by alsayyed on Drying and Processing
Last post February 12, 2006, 07:58:11 AM
by Ga_Boy
Need advice on using freight container for klin.
Last post April 14, 2006, 08:17:38 PM
by Den Socling
