Over length logs
Started by bic, August 22, 2016, 04:29:09 PM
bic
Hey folks, can someone point me to where I can get info for the above, my lt28 will cut 21' and I need a ridge beam cut 34'
I know there are threads on here but just can't seem to find them
Thanks ahead
Bic
LT 28 Woodmizer
where there's a mill there's a way
LittleJohn
...I have no experience with sawing logs longer than my mill, but I think there are 2 options:
  • Buy bed extensions
  • Do the cut, scoot and cut technique
bic
Any idea where I can find info on the "cuttin,scootin,and cuttin" technique
LT 28 Woodmizer
Go to "extras". It's in the Menu Bar,the one that starts out with Home,Help,Search. You will see Knowledge Base,click onto that,go to Milling-Bandmills,click onto that,you should see Sawing logs longer than mill.
ChugiakTinkerer
Quote from: thecfarm on August 22, 2016, 08:19:28 PM
Slick!  Useful trick for this newbie, and a really useful resource.  Thanks for pointing it out.
Woodland Mills HM130
bic
Thanks old friend, looking after me again ha ha
Bic
LT 28 Woodmizer
carykong
If this is near conventional framing with rafter and ridge board, you could go with two ridge boards 17' long
Join two rafters at the joint
Won't see it
Much easier to lift and install
Cedarman
Just got an order for 12   4" x 8" x 34' which we will saw on our 22' mill.  Logs must go through our 20' door.  We have done this several times and know the drill.  Now I will have to come up with some long ERC between now and spring.  I do have an 8 acre tract that has a lot of big straight cedar.  At least I have a plan at the moment.
We use the cut and scoot method.  Pallet jack with stack of pallets helps lift log and beam and move them back and forth.  Hydraulic toeboards are precious.
