Ordered a WM LT28
Started by WranglerSS, September 17, 2016, 07:49:19 AM
WranglerSS
Been reading up in the forum and learning a lot about making boards outta logs. I should get my new mill in around 4 weeks hopefully and will start building a logging arch next weekend.
Kubota L3240
Kubota RTV 900
Woodmizer LT28
Woodmaxx 8h Chipper/Shredder
Ox
First, welcome to the forum.
Second, good news on your new mill!  Hopefully you'll keep us updated.  And for the record, pictures are king.  Especially when you build your new log arch (hint, hint).  :D
Good Morning and Welcome to the Forestry Forum, WranglerSS.  Congratulations on the new LT28.  Go ahead and add a couple of Logrite cant hooks to your order.  I would recommend a 48" and a 60".   ;D
tnaz
Another welcome WranglerSS, congrats on the new mill. 8)
Terry
samandothers
Yep welcome!
Look forward to pictures of the new toy!  I it will be like waiting for Christmas!
Chuck White
Welcome to the Forestry Forum, WranglerSS, and congratulations on the new mill!
You will like it.
What's the plan for the lumber?
WranglerSS
Thanks for welcomes. My first project will be a 36x48 building to park the RV, boats and tractor.  Pics will be forthcoming.
Kubota L3240
Kubota RTV 900
Woodmizer LT28
caveman
Welcome WranglerSS.  What engine did you order with your LT-28?  Any optional equipment?  We added an hour meter and a small brass ball valve to the blade lube line so that we can set the flow with the tank valve and use the ball valve to turn it on and off.  We also keep a scissor jack on one end to level big logs that have taper.  Good luck with your new mill.
Caveman
WranglerSS
I got the 19hp Kohler and they had a sale on the power drive and deck kit which includes the toe boards,  winch and log turner.
Kubota L3240
Kubota RTV 900
Woodmizer LT28
caveman
I have never used the rope crank feed apparatus but I do like the power feed option.
Caveman
JustinW_NZ
Welcome and congrats on taking the leap into 'milling..  :)
Cheers
Justin
Gear I run;
WranglerSS
So while waiting for the mill I spent the weekend building my logging arch.
Here are a couple of walnut logs I used for testing.
Kubota L3240
Kubota RTV 900
Woodmizer LT28
WranglerSS
One more picture of the winch controller mount.
Kubota L3240
Kubota RTV 900
Woodmizer LT28
Ox
Looks good, bud.  You'll be a milling fool here 'for too long.
Crossroads
Congratulations on the new mill!!!
carykong
Good fortune with your mill. I have an LT 27. Perfect mill for barn and shed construction.
WV Sawmiller
WSS,
  Good luck on that log arch. Good looking rig but I'm concerned about it bowing under the weight of a big log. You'll find out real quick if you need to add some extra braces into position on the logs for reinforcement. One great feature is the light weight will allow you to manually place the arch into position on/over the log which is often faster than trying to back it into position. Let us know how it works.
WranglerSS
Thanks for the replies.
WV - the backbone is 1/4' wall plus the lift points are close enough to  the rear frame and front gusseted down tube there shouldn't be an issue.
Here is a new picture with paint.
Kubota L3240
Kubota RTV 900
Woodmizer LT28
breederman
The handle on the tongue is a nice touch !
Together we got this !
ChugiakTinkerer
Quote from: breederman on October 07, 2016, 05:34:21 PM
Indeed!  How's the tongue weight empty?
Edit to add: Mea culpa, my first words should have been to mention how nice it looks with it's clothes on.  A fresh coat of paint makes even my work look acceptable.
Woodland Mills HM130
Kbeitz
They start getting a little fishy when you put large long logs on them.
The longest I put on so far was 56 feet long and I wont do that again...
First picture is only 34 feet long...
Love machine shop work
and Wood work shop work
And now a saw mill work
tnaz
What spindles did you uses?
WranglerSS
Wow, 34' is long. The longest I have and will do is 20'.
The spindles I used were the 1 1/16 straight with 5 on 4.5 bolt pattern.
Kubota L3240
Kubota RTV 900
Woodmizer LT28
Kbeitz
Quote from: WranglerSS on October 07, 2016, 10:57:21 PM
The 56 foot log almost jackknifed my jeep when I drove over a hump in the road..
