Lt 40 tensioner
Started by Ricker, October 30, 2016, 05:16:10 PM
Ricker
Friday afternoon as I had 2 logs left to saw for the day a couple friends stopped in and we visited for a hour or so and I decided to call it a day.  Well I went to the mill this morning for a couple boards and discovered that I never released the pressure on the tensioner.  It was at 3000 lbs when I walked away Friday and it was down to about 1500 this morning.  I released the remaining pressure and went about the day and will be trying to saw tomorrow. Been bugging me all day, anyone ever do that and cause any damage?
ncsawyer
You should be fine.  As the temperature dropped overnight, so did your hydraulic pressure.  If you left 3000 psi on it in the full sun in summer time, it might get hot enough to raise the pressure enough to mess up the gauge or a seal.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
POSTON WIDEHEAD
Look at it like this.......you got away with one.  :D :D :D
Usually once or twice its ok.....but sooner or later if ya keep doing it, you'll return to see your PSI gauge full of ATF.
This is not good. Kirk and I always remind each other to take the pressure off the blade at the end of the day and before we go to lunch.
I've even went to the mill just to check late at night.
Ohio_Bill
Quote from: POSTONLT40HD on October 30, 2016, 05:55:56 PM
That's funny, Thought I was the only one that does things like that. I blamed it on my OCD.
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
Ricker
Thanks, I should be able to sleep tonight. It's the first time I forgot but I have gone down a dozen times with a flashlight cause it couldn't remember releasing it.
If you always removed the blade at the end of the sawing day, you would never forget to release the tension.   ;D
Kbeitz
It's not much difference than leaving your car up on a jack...
Love machine shop work
and Wood work shop work
And now a saw mill work
DR Buck
Quote from: Magicman on October 30, 2016, 09:50:22 PM
MM --  What's the purpose of removing the blade at the end of the day?     If I only cut a few hundred board feet or less and haven't hit anything I start the next day with the same blade.    I leave it on until it needs to be changed.
I saw portable so my next day is always subject to change either by myself, the customer, or the weather.  We may have good intentions of sawing the next morning and it may be several days or a week before I get back.
There is always an amount of wet sawdust between the blade and bandwheel.  This will cause the blade to form rust where this contact is made and I don't like that.
I have a day ending and day startup ritual with my cleaning and lubing.  I like everything neat and tidy.
Safety in case a child happens to mess around the sawmill after I leave.  I often see little footprints in the sawdust, so it does happen.  That blade would/could be an irresistible fascination.
Chuck White
I agree with Lynn, if you leave the blade on overnight, there will be some rust forming wherever the blade is in contact with the blade wheels!
It only takes a couple of minutes to remove the blade and wipe it down.
petefrom bearswamp
I'm with Dr Buck.
I take my blades off when they get dull.
The only time I have had rust is when I leave it for several days and the rust disappears the next time I saw.
I do relieve tension at lunch and the end of the day
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
I always de-tension at lunch time and hang my leather apron on the tension lever as a reminder to tension up before resuming sawing.
POSTON WIDEHEAD
Quote from: POSTONLT40HD on November 01, 2016, 08:27:27 PM
Looks like a shirt.  ;D
I am glad that you did not say skirt.   ;D
POSTON WIDEHEAD
