Dynamic Green Products Inc.
Author Topic: Here's what to do with loose tie down ends  (Read 1257 times)
Offline Brad_bb
« on: November 30, 2016, 12:37:50 AM »
I've been doing this ever since I saw the video a couple months ago.  Works great!
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Here's what to do with loose tie down ends
« Reply #1 on: November 30, 2016, 01:26:43 AM »
I'll have to try that.
Jim Rogers
Offline ljohnsaw
« Reply #2 on: November 30, 2016, 01:33:41 AM »
Yep, that's what I do (the loop trick).  I am very paranoid of straps flailing in the wind and getting caught by a tire :o  I see it all too often on the road.
Edit:  That's also how I store my straps.  I pull all the loose end up so the hook is by the ratchet, spool it up, loop it and put them in 5 gallon buckets with pieces of plastic barrel that I use as edge guards.
John Sawicky
Offline cbla
« Reply #3 on: November 30, 2016, 05:44:02 AM »
Neat. I have not seen that method before.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #4 on: November 30, 2016, 05:12:04 PM »
I once had a loose strap get under my truck tire as I was
driving through an intersection. I was sure some one had
broadsided my truck. I could find no damage but it sure
rocked my truck. I snapped a 1=1/2" strap right off.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline jmouton
  • never enough time
    • Log-Gistics
« Reply #5 on: November 30, 2016, 07:27:07 PM »
ill have to try that if i remember it
lt-40 wide ,fiat tractor,bobcat,international flatbed,10 ton trailer, stihl 075,041,029,066,and a 2015 f-350,and a oldwheel loader ,grapple system coming soon!!
Offline 47sawdust
« Reply #6 on: December 02, 2016, 04:42:08 PM »
I love videos like that.Pleasant guy doing the presentation with helpful info for all.
 Thanks,Brad
Mick
Offline barbender
« Reply #7 on: December 02, 2016, 11:36:36 PM »
 Thanks,Brad
That's what I thought, too. In fact, I had to go right out and try it ;) It works very well🖒
Offline John Mc
« Reply #8 on: December 03, 2016, 08:14:44 AM »
... That's also how I store my straps.  I pull all the loose end up so the hook is by the ratchet, spool it up, loop it and put them in 5 gallon buckets with pieces of plastic barrel that I use as edge guards.
Good idea. No matter how neatly I put them away, my straps always end up a tangled mess.
it never ends
Started by coxy on General Board
Last post June 02, 2014, 01:09:20 PM
by isawlogs
sad
An Era Ends
Started by DanG on General Board
Last post December 28, 2009, 06:39:45 AM
by fishpharmer
Thin ends on LT 40
Started by highleadtimber16 on Sawmills and Milling
Last post May 27, 2017, 09:56:23 AM
by PC-Urban-Sawyer
Sealing log ends
Started by learner on Drying and Processing
Last post June 10, 2019, 10:51:13 PM
by doc henderson
