Author Topic: alternator belt PN  (Read 466 times)
Online LeeB
alternator belt PN
« on: January 07, 2017, 12:07:13 PM »
Anybody know the non woodmizer part number for the alternator belt on a 98 LT40 super with 40 hp Lombardini?
Offline drobertson
Re: alternator belt PN
« Reply #1 on: January 07, 2017, 12:27:16 PM »
Lee I found a good formula on google search, simple, approx. For length of belt between pulleys, it was the top pick frenz? Something, anyway tried to copy paste, its there good luck man
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: January 07, 2017, 01:27:03 PM »
Lee, NAPA 060407
You will have to loosen the brake to allow the engine to drop down enough to remove the drive belt and install the alternator belt.
Online LeeB
« Reply #3 on: January 07, 2017, 01:56:56 PM »
Thanks guys. i found the number after I looked again.
Need some alternator belt help
Started by Nomad on Sawmills and Milling
Last post December 05, 2012, 08:56:23 PM
by Beavertooth
Alternator belt for 2006 WM LT40
Started by WoodenHead on Sawmills and Milling
Last post December 28, 2020, 09:38:34 AM
by Stephen1
Alternator Belt Problem Solved!
Started by ncsawyer on Sawmills and Milling
Last post March 25, 2016, 10:37:31 PM
by Magicman
Woodmizer Battery Light and Alternator Belt
Last post May 17, 2015, 07:46:59 AM
by MartyParsons
