Author Topic: kubota cylinder head fix  (Read 1829 times)
Offline Reddog sawmill
« on: February 05, 2017, 02:31:17 PM »
Hi guys first post here and i need some advice. I have a kubota diesel in my skid loader the machine hasnt ran in a couple of years.i just tore the head off of the engine today to inspect the cylinders and to my horror i noticed a large crack in the head about 1.5 inches long extending under the valve. I dont have much money to play with at the moment and dont NEED this machine but would really like to get it going because it was kind of a pet project for my grandfather who recently passed away and i. I know cast iron is a tricky material to work with but i was wondering if v-ing out the crack and brazing was an option? Not much to loose really but i cant afford a cylinder head at the moment so i would like to fix this one. Thanks in advance for the replies.
Offline coalsmok
Re: kubota cylinder head fix
« Reply #1 on: February 05, 2017, 03:47:45 PM »
Welcome to the forum
You are in for spending the cash. I don't know of an effective way to repair a head with weld, especially one cracked into the valve seat and probably the intake or exhaust passage.  Even so you would still need the head and valve seat resurfaced after welding. Since you don't seem in a rush eBay and equipment graveyards may be in your favor for a decent used head.
Offline Gearbox
« Reply #2 on: February 05, 2017, 03:55:46 PM »
A crack into the valve . Weld it is a sure fire way to drop a valve seat into the cylinder and ruin the rest of the engine . If you  have a diesel skid loader that's worth $ 5000 and up . whats it worth now $ 1000 - 1500 .
Offline scsmith42
    • Whispering Pines Farm
« Reply #3 on: February 05, 2017, 04:11:13 PM »
Many years ago I owned a machine shop and we welded up a lot of heads.
Your best bet would be to obtain a replacement head.
If you opt to have it welded, your best option is TIG welding with either nickle or stainless filler.  After welding up the crack have the valve seat machined and a replaceable seat installed.
Alternate options are stick welding with either nickle or stainless, or oxy-acytelene brazing.
All of these have the potential to crack.  Welding cast iron is very tricky and the shops that do this will typically preheat the entire head, weld it, and then post heat it to bring it down slowly.  Other tricks are to peen the weld to stress relieve it immediately after welding, pack in sand after welding, etc.
Brass (brazing filler rod) is not a good choice for the valve seat area.
Tom's 3638D Baker band mill
Offline MT logger
« Reply #4 on: February 05, 2017, 04:23:37 PM »
Witch engine is it and where are you located I have a few Kubotas and parts.
« Reply #5 on: February 05, 2017, 04:33:22 PM »
Thank you mt logger it is a d1402 3 cylinder
« Reply #6 on: February 05, 2017, 05:57:43 PM »
Oh and i am located in maryland
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #7 on: February 05, 2017, 07:06:04 PM »
If it was my engine I would cold weld it with ni-cad arc rods.
V it out an just put a dab of weld on it and peen it with a needle
scaler and walk away. After it's cold to touch put another dab on it.
If you see any bubbles in the weld grind it off and do it again.
The bubbles come from the heat of the weld burning off gasses.
Peen after each weld and don't let it get hot. Sometimes it helps
to drill a hole at the end of the crack. The crack is always longer
than it looks. Nicad stands for nickel cadmium.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline MT logger
« Reply #8 on: February 05, 2017, 08:22:29 PM »
Sorry closest I have is some 1505 4cylanders.
« Reply #9 on: February 05, 2017, 10:24:50 PM »
Thanks for the advice guys. Kbeitz that is exactly the solution i was looking for, i figure if the head is already no good it wouldnt hurt to at least try to fix it. Now i need to source some ni-cad rod and try to weld her up.
Offline scsmith42
« Reply #10 on: February 05, 2017, 11:23:59 PM »
than it looks.
Your recommended procedure is a good one but I think that you mean "Ni" rods and not "N-cad" rods.  Ni stands for "nickle", which is the predominant arc rod for cast iron. Ni-cad stands for "Nickle Cadmium" which is not a welding rod (and cadmium fumes are not the best thing to breath in when welding...).
Offline Qweaver
  • The cabin is done and we love it
« Reply #11 on: February 05, 2017, 11:59:37 PM »
Welding cracked heads is so iffy because if you do not get the entire crack fully welded, it will certainly crack again.  I would try very hard to find a good used head.
Offline Kbeitz
    • My Hobbies
« Reply #12 on: February 06, 2017, 06:12:22 AM »
than it looks.
You lost me... I can see my (i) can't you ?
Offline Qweaver
« Reply #13 on: February 06, 2017, 11:39:06 AM »
It is not a ni-cad rod but just a nickel rod---no CAD.  Super Missile Weld is also a good choice for cold welding cast.  I've welded several cast heads...not always successfully...but always costly.  Also welded several Aluminum heads, always successfully.  I'd try very hard to find a good used head!!
« Reply #14 on: February 06, 2017, 04:28:42 PM »
ok guys lots of good answers here yet none that really satisfy my budget, next question would be what about repowering it with a similar hp and size gas engine? Should be as easy as coupeling the engine shaft to the hydro pump shouldnt it? Or am i overlooking somthing important?
Offline Kbeitz
    • My Hobbies
« Reply #15 on: February 06, 2017, 07:43:25 PM »
Ni-Cad rods...
http://www.practicalmachinist.com/vb/fabrication-cnc-laser-waterjet-plasma-welding-and-fab/nicad-welding-rod-131605/
It's what I use... On the box Ni-Cad.
It's what I just used to weld this cast iron part.
Offline scsmith42
« Reply #16 on: February 15, 2017, 04:20:32 PM »
Ni-Cad rods...
Could you please post a photo of the box label?  I would like to research this further.  Thanks much.
3-53 Detroit Cylinder Head
Started by boscojmb on For Sale
Last post March 08, 2015, 10:16:34 PM
by boscojmb
6068t cylinder head?
Started by 1270d on Forestry and Logging
Last post March 27, 2012, 10:30:34 PM
by 1270d
Aluminum cylinder head
Started by Canadiana on Chainsaws
Last post March 01, 2018, 02:31:04 PM
by Grandedog
Detroit 353 cylinder head
Started by road_monkey on For Sale
Last post April 16, 2014, 04:38:56 PM
by treeslayer2003
