Author Topic: blade sharpener  (Read 3612 times)
Offline Jmiller160
blade sharpener
« on: April 26, 2017, 11:25:46 AM »
Are there any affordable hand sharpeners or possibly homemade options?
Offline paul case
  • Original wearer of the PCM.
Re: blade sharpener
« Reply #1 on: April 26, 2017, 11:40:12 AM »
I had an EZ boardwalk sharpener and I liked it fine and it worked well for the money.
They are a sponsor here. Icon in the column to the left of the page.
PC
pc
Offline fishfighter
Re: blade sharpener
« Reply #2 on: April 26, 2017, 12:26:20 PM »
Built mine for $25. Well, bought a old craftmen radial saw.
It takes me about 15 minutes to sharpen a blade. But I have more time then money. :D
The blade run thru a piece of 2x4 that I had sawed a slot 1" deep. It is tight and the blade holds good.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: blade sharpener
« Reply #3 on: April 26, 2017, 05:24:15 PM »
And I used a Sears chop saw....
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline bags
  • Location: Up high in the Colorado Rockies, Westcliffe ,CO.
Re: blade sharpener
« Reply #4 on: April 26, 2017, 09:18:06 PM »
I use a Tek Motion chainsaw sharpener. You can pretty much use it right out of the box without build'in a base bracket. Undo the chain stop and turn it around and block the chain adjustment bar and its good to go. I grind the micro cracks out of the gullet with a dremmel.
I'd post a picture but me and FF picture post'in don't get along.lol.
You can probably find a pic in my gallery.
Offline fishfighter
Re: blade sharpener
« Reply #5 on: April 27, 2017, 05:00:22 AM »
With the radial saw, I'm using a 1" wide stone that I dressed it out to do the gullet too. I keep a new 7 degree blade on hand to dress the stone on. So far I been very happy with the way the blades are sawing. ;D
I had a bunch of 10 degree blades that are now 7 degree which I found that my little mill likes best. ;D
Offline bags
Re: blade sharpener
« Reply #6 on: April 27, 2017, 07:34:54 AM »
In that closeup pic of your blade stop--- it looks like your 1" stone does a nice job.
Offline DDW_OR
Re: blade sharpener
« Reply #7 on: April 27, 2017, 09:35:16 AM »
I like the idea of one sharpener for two things.
"I grind the micro cracks out of the gullet with a dremmel"
maybe have a wider grinding wheel that is shaped for the band blade?
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline DDW_OR
Re: blade sharpener
« Reply #8 on: April 27, 2017, 09:43:14 AM »
my sharpener came with the Timberking when we got it new.
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: blade sharpener
« Reply #9 on: April 27, 2017, 05:45:01 PM »
My old woodmizer sharpener
And the duel tooth setter I made
1992 LT40HD
Offline fishfighter
Re: blade sharpener
« Reply #10 on: April 27, 2017, 06:01:14 PM »
If only I had the money to spend, but I only saw for myself. ;D Got a pineywoods setter that I made. ;D
Offline Darrel
Re: blade sharpener
« Reply #11 on: April 27, 2017, 09:09:39 PM »
Hey Fishfighter, if you look closely, you'll see that my setter is basically a Pineywoods setter that I mounted on a frame and put a couple of handles on.
1992 LT40HD
Offline bags
Re: blade sharpener
« Reply #12 on: April 28, 2017, 09:01:31 PM »
Thanks for pull'in up the picture DDW_OR.
I'm gonna check around and see if I can match a wider wheel up to the grinder so I can get farther into the gullet. It takes a 7/8's arbor and the wheel is 5 3/4" so I'm think'in I might have quit the time find'in what I want for the job.
Offline fishfighter
Re: blade sharpener
« Reply #13 on: April 29, 2017, 07:31:12 AM »
Check ebay. A bunch come with inserts.
Offline bandmiller2
Re: blade sharpener
« Reply #14 on: April 29, 2017, 08:35:02 PM »
Bags, 7/8" is kinda a standard size for wheels. They are held on with a collar and a hex head screw, you will need to find a longer screw, probably metric. Just for chuckles try sharpening only the face with the setup you have, you may find you get many sharpening's. Frank C.
Wood Mizer Blade Sharpener and Setter (Blade Maint Pkg) - SOLD...
Started by Warren on For Sale
Last post March 02, 2010, 02:01:48 PM
by dbnair
question
Blade Sharpener
Started by Jacar on Sawmills and Milling
Last post August 06, 2003, 07:03:41 PM
by Russ
Blade sharpener
Started by ahlkey on Sawmills and Milling
Last post July 18, 2009, 10:33:09 AM
by pdhntr
cheap blade sharpener
Started by tazz on Sawmills and Milling
Last post July 27, 2010, 05:49:53 PM
by paul case
