franklin 405
Started by coxy, May 02, 2017, 07:00:31 PM
coxy
has anyone ever done the parking brakes on one the dealer says you have to pull the tranny and takes about 3-4days to do it  :o  but we never did just pulled the  back drive shaft and turned the skidder all the way one way and pulled them out it took some figuring on how to keep the disks from falling down when installing the  housing  but we pulled the hub that rides on the shaft with the splines put it in the pressure plate housing slid the disks in then put a 5/16x21/2 in long bolt in there to keep the inner hub from sliding out of the last disk till we got it bolted on then pulled the bolt out worked like a champ  8)( don't forget to put the Allen bolt in before you put it together errrr its to long and wont clear the frame by the lower center pin)
kiko
Have done quite a few of those in frame as well as the service brake on the front of the transmission.
