Author Topic: might buy a Belsaw M-14  (Read 972 times)
Offline KFhunter
« on: July 24, 2017, 06:36:10 PM »
I've never seen one of these running.  Hoping you all can give me a few pointers before I go look at this saw, see what I'm getting into with this.  The ad say's it's been sitting 20 years put up, comes with a diesel engine but no details on the engine.  I do have a tractor to power it but I would prefer it's own power head as I'll need the tractor to move logs.
I want to make corrals, barn, equipment sheds and farm stuff - home use no outside sales.
What would be a value on this?
Offline KFhunter
Bellsaw M-14 purchase advice
« Reply #1 on: July 24, 2017, 06:37:51 PM »
What is that wooden trough in the picture?  Has a pulley on one end?
Thinking it could be a sawdust conveyor?
Offline KFhunter
Re: Bellsaw M-14 purchase advice
« Reply #2 on: July 24, 2017, 06:42:41 PM »
Thank you for merging my two threads  ;D
Online Don P
    • Calculator Index
Re: might buy a Belsaw M-14
« Reply #3 on: July 24, 2017, 07:46:26 PM »
I don't recognize anything except the round pipe in the bucket as being from the saw, that's the feed handle, slips over the 90 bent shaft at foot level in front of the mandrel. The blade guide looks different or something is going on there, on the rail ~2' in front of the mandrel. Splitter looks stock behind the mandrel shaft, both collars and nut look to be there, a wrench came with it. Make sure the shaft end of the pto shaft is the same size as the mandrel and its not just a random pto shaft, I don't see the shear bolt plate on it but it might be hanging below the table in that pic. It is set up for belt drive off the engine now. See if the main bearings are free and that the feedworks bearings are ok. Slop in the carriage wheels, missing wheels etc.
Look the blade over well, is it bent, cracked, galled in the collar, that is a couple of grand new and that is about all the mill is worth.
Offline moodnacreek
  • Sawin by the notches
« Reply #4 on: July 24, 2017, 08:45:11 PM »
At least it's steel. Plan on new mandrel bearing inserts . The saw collars should be cleaned up carefully [they are tapered] and checked for wobble . Although the saw is an expensive item, only 1 nut holds it on, it's the mandrel that's most important. You will hate the set works on a bell saw. Not good for logs much over 20". I'd say it's worth 500 to 1000 max.
Offline paul case
  • Original wearer of the PCM.
« Reply #5 on: July 24, 2017, 10:23:55 PM »
I had on like that.
I gave $1000 for it and heated the blade trying to saw some hickory. Sold it for $2500.
It was easy to set up and figure out the works. Would work well on small logs. Several here have them. Belsaw m-14 made in Kansas City.
Yes the wooden thing on top is probably the sawdust conveyor.
PC
pc
question
Help belsaw m14
Started by mikej on Sawmills and Milling
Last post December 17, 2005, 08:41:04 PM
by beenthere
M14 Belsaw
Started by Log Jammer on Sawmills and Milling
Last post August 02, 2019, 07:28:02 PM
by Log Jammer
Belsaw m14
Started by Mark K on Sawmills and Milling
Last post June 11, 2012, 03:45:43 PM
by Mark K
Old Belsaw
Started by Corley5 on Sawmills and Milling
Last post January 07, 2007, 08:44:00 AM
by snowman
