Author Topic: LT40 Super hydraulic/LT50/LT70 DC Hydraulic pumps specs question....  (Read 1434 times)
Offline Percy
  • Resident trouble maker
My guess is all have pretty much the same units working in parellel. My question is what is the GPM rating of each unit. I cant seem to find specs in my manual. The reason I need to know is after 10,500 hours, one of the pumps has swallowed the big onion. Not the electrical part but the pump itself. I want to replace both with a pair of similar 12 volt units that will fit but are two stage pumps. They go like crazy when there is a small load on them, the specs say at 610 psi the pair in parellel will do around 6.6 gallons per miniute and around 2.5 at high pressure...My mill has a relief valve built in I believe so no worrries of over stressing anything. I think this could speed up hydraulic "waiting time". Am I thinking correctly here??? Heh
Offline Larry
Re: LT40 Super hydraulic/LT50/LT70 DC Hydraulic pumps specs question....
« Reply #1 on: August 03, 2017, 08:55:10 PM »
The problem I see is if the pumps shift from low speed to high speed at the wrong time.  Say you are turning a big log at low speed and without warning the pump shifts to high speed due to a decreasing load.  Might spin the log into the next county. :D
Not sure if this would be a problem or not.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #2 on: August 03, 2017, 09:21:16 PM »
Hello,
  pumps are 2 gal per min. Relief is set at 2200 psi. Yes the Super and the old LT70 are 4 gal per min. 2+2=4.  I would think if you have the Super the hydraulic lines are larger I.D. you could go to 8 gpm. Any more gpm and you will start to have issues. Weakest link deal.
Hope this helps.
Marty
The Super LT70 is 8 gpm at idle. I think if you run the blade at load rpm it goes to 14 gpm. Very dangerous to have this much gpm. This valve bank different than the 40 Super.
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline Percy
« Reply #3 on: August 03, 2017, 10:10:04 PM »
Thanks Larry and Marty. I think I will go for the two stage pumps. Might be a tad slower at a heavy/lift/turn/whatever but it seems I spend alot of time waiting for the loader to drop/side supports to position etc. If I wasnt so long in the tooth, Id get that super 70 in the wide model. My 70 is over 14 years old and does the job. Just slow hydraulics and up/down. Id like to fix that up down thing eventually. Maybe an air cylinder in the mast... Hmmmm
Offline JB Griffin
« Reply #4 on: August 04, 2017, 05:59:34 PM »
Marty, I'm curious to why you say 14gpm is "very dangerous". Baker runs 12.5 gpm on there Dominator and Cooks run 14 on the AC36.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #5 on: August 04, 2017, 06:10:28 PM »
Is all of that going into the log handling, or is it split with head travel functions?
Offline JB Griffin
« Reply #6 on: August 04, 2017, 06:50:27 PM »
If the head ain't moving it ain't using no flow.
    • My homepage
« Reply #7 on: August 04, 2017, 07:14:45 PM »
Ok. Didn't know if it used a multi section pump with dedicated flow for each function.
Offline JB Griffin
« Reply #8 on: August 04, 2017, 09:05:00 PM »
The baker at work has a standalone hyd powerpack that runs every function on the mill.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #9 on: August 04, 2017, 09:58:07 PM »
Percy don't worry about how long your teeth are, sawmill men arent allowed to retire til after 80 you got plenty of time to pay it off and why waste all that time waiting on your head to go up and down lol
Boy, back in my day..
Offline Percy
« Reply #10 on: August 04, 2017, 10:35:58 PM »
That would be the ultimate solution, cept Im really low on ac power at my millsite.
Ya I hear you. Im on the "freedom 85 " retirement plan :D That super sounds good..or a 3500/4000....but theres that ac power thing again. Im goin out for lottery tickets rite now....later
Offline 4x4American
    • Website Link
« Reply #11 on: August 04, 2017, 11:44:42 PM »
The 70 super is only offered with a diesel engine as far as I know so that solves that problem!
Offline Percy
« Reply #12 on: August 05, 2017, 05:22:52 PM »
a little over 90 grand in canukistsanian currency.
Offline JB Griffin
« Reply #13 on: August 06, 2017, 09:48:10 AM »
Percy, why not build a gas or diesel powered hyd unit?
One of those HF 22hp should pull a 10gpm pump and thats better
than stock forsure.
Offline Percy
I
than stock forsure.
This is prolly what I'll  eventually do but  i think a 5 hp diesel would be enough doncha think? It would have to be running all day
Offline JB Griffin
« Reply #15 on: August 06, 2017, 12:56:15 PM »
The old rule of thumb I heard was 2hp to1gpm.
LT40 Super hydraulic pumps
Started by JustinW_NZ on Sawmills and Milling
Last post November 25, 2012, 04:26:09 AM
by JustinW_NZ
question
hydraulic flow for WM LT50 vs LT40 super
Started by bonecutter on Sawmills and Milling
Last post March 02, 2019, 04:53:39 PM
by bonecutter
Sparks, Marty, any LT70/LT40 Super Hydraulic owners familiar with this problem
Started by Percy on Sawmills and Milling
Last post September 10, 2018, 08:13:05 AM
by PA_Walnut
LT40 hydraulic pumps
Started by D6c on Sawmills and Milling
Last post May 19, 2017, 02:07:36 PM
by nativewolf
